could someone please give me the torque setting of 1. the craddle which holds the crank in, i did mine at 40 lb/in is this ok
2. the head, i read some where around 100 lb/in
3. the bolts which hold the con rods to the crank, i read in the 26 workshop manual 14 lb/in and then 60 to 65 degrees with an angle wrench, and i dont have an angle wrench.
4. and anything else that is important
thank you.
https://www.sau.com.au/forums/topic/280934-torque-settings-for-a-2630/
i wouldnt be using rb26 torque settings on rb30 bolts, they are different sizes from memory. I have a vl commodore workshop manual in the shed ill grab it tommorow and post the specs up for the rb30 specific stuff unless someone else beats me to it.
If your using rb26 headbolts then use the 26 torque specs for them, but main bolts and rod bolts i would definately use the rb30 specs.
Edited by unique1
who is the cock sucker who edits the posts on this thread? i looked up on monday and there was about 5 replies, now there is only 2, some guy had written up a massive informative post which is now not there, what the fu*k is going on? for the people whos posts that have not been deleted, i thank you for your input. i would like to know the torque settings of the conrod bolts by the weekend if anyone has them, cheers
Dumb shit, the forum went down a few days ago. There have been posts about it.
TORQUE SETTINGS - for factory bolts, nuts, studs ect. Other manufactures such as ARP have their own torque settings that are listed on the box.
Cylinder head bolts - 10mm 'allen key' type bolt
1st stage - 29nm
2nd stage - 78 nm
3rd stage - loosen completely
4th stage - 29 nm
5th stage - 88 nm
Corner cylinder head bolts - 10mm hex nut
8 nm
Main bearing cradle bolts - 16mm IIRC
54 nm
Connecting rod bearing cap nut - 10mm iirc
1st stage - 16 nm
2nd stage - 44 nm
thank you mr 200 for the torque settings of the rb30 bottom end, you are a champion. i am not a dumb shit though, i dont spend alot of time on sa and didnt realise it had crashed. it is an excellent site for getting information. thank you thank you yes sir, thank you.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
