hay guys got a White Series one r33 skyline shell that is fully rego'd.
My mate Crashed his 33, Its a write off, but Plates are fully rego'd
Plates have no rego atm as it ran out.
Need it gone ASAP to fund my new car..
Asking $1000 !!
Adelaide
0411592938
https://www.sau.com.au/forums/topic/281017-r33-regod-plates/
Asking $1000 !!
Adelaide
0411592938
Nah,
shell has not been classed as a write off.
So someone can fix it. Cause it still has rego.
Doesnt make sense? So your selling the whole damaged shell for $1000 or just the tags off the car {EDITED this part..}
The car can be rego'd but has no rego on it atm cause it has ran out.
Im sellin the whole shell, would need alot of work.
Has no interia, no motor or box, no front end, no rear end, front end has been cut to get motor out, Dash bent,
My mate Crashed his 33, Its really bad and has nothing left and pretty much everythings bent,
Shell can be rego'd but has no rego atm as it ran out.
Asking $1000 !!
Adelaide
0411592938
Let me get this straight,
You are selling compliance plates for a car that has been written off?
As in taking the plates ÖFF the shell so that someone can use the numbers to rego their car?
NO!
Im sellin a rego'd shell
Ok Cool, from the wording (before the edit) it sounded like you were trying to sell just the tags off the shell which is a big no no.
Best of luck selling the shell mate.
Cheers,
Cheers,
haha yea nah worded it wrong!
How do i change it?
cheers mate
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
