why would you have both?? If you're talking about a pod filter followed by a panel boxed filter.. then there's no point except for induction sound. Having both would just add restriction to your airflow and make performance worse. Unless you're driving through a dust storm every day of the week I fail to see any benefit or reason. It's either one or the other mate.
this is my setup on my 34
OK, I see a heat shielded pod. Where's the panel filter in that pic?
but i havent seen anyone talking about having both? can it be done?
I know its not "legal' but im talking performace wise, not legality.
It can be done, but from a performance perspective its pointless. You're just adding needless complexity and you won't see any more airflow.
If you run the pod and panel in series, it just adds an intake restriction because the engine has to suck air through 2 filters. A single filter will provide enough filtration so the resistance decreases performance but doesn't add any safety.
If you run them in parallel (so you use a Y pipe to join the 2 together) then your total airflow is still restricted by the size of the intake pipe downwind of the Y pipe. You could just have 1 pipe of that diameter and see the same cross sectional flow. At the same time, 2 different airstreams merging creates turbulence, which is also bad for airflow.
Ah the good 'ole panel vs pod with a twist.
Basically in all the tests that have been done by various car magazines (both online and paper) the consensus is to get a high flowing non-oiled panel filter. Plus thats my opinion too. Feel free to flame away - honestly I don't care if you have a pod but for the love of god it better be shielded.
Autospeed has some nice articles about induction here:
Part 1: http://www.autospeed.com/cms/A_1361/article.html
Part 2: http://www.autospeed.com/cms/A_1370/article.html
Part 3: http://www.autospeed.com/cms/A_1379/article.html
Part 4: http://www.autospeed.com/cms/A_1829/article.html
Good stuff in there.
As to why not pod and panel? The question is why would you? More restrictive. No gains. More convoluted piping. Probably not that much noise (if your into that kind of thing). Costly (relatively).
Essentially a lot of work for no real gain. The question is why would you?
Edit: added article
Edited by R33_Dude
my car has a panel filter and a pod filter set up, but there is pannel filter mouth and the pod aswell which doesnt go through the filter lol i didnt do this it was like that when i got it, pretty weird, the pod sits down in the front bar and piping joins up behind the panel filter, which has a mouth sitting behind the headlight.
I am getting rid of the filter soon and having the pod sitting by itself down within the front bar tho,
Edited by r32na
do u mean something like this?
That a Good Set-Up Aswell, This Is What Iv Fitted To My 33Gtr-Heaps Better Then A Panel Filter!
i would like to cover my pod up just for a more tidy look
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
