Before I even decide if I want to attempt a road tune myself, I will need to set the correct injector size when I put my 550cc injectors in. I'm reading the relevant section in the manual, but there's a case of too much information in here.
The basics seem fairly straightforward. 370/550=.6727, so I assume I just stick 67.3% in the Fr-Pr field. But where do I find the injector lag time? I also presume the secondary injector field isn't relevant to me, so do I leave it the way it is or make it the same as primary, or zero it out?
Also are there any other settings I need to change along with the above settings, such as cold cranking or water temp correction? Or are they all ok to leave as-is once I set the above properly?
https://www.sau.com.au/forums/topic/28104-powerfc-injector-size-setting/
JimX, I just used the injector correction in the' ign/ijn' function in settings menu. This is not perfect, but it allows you to drive the car, then get it tuned ASAP. WORD OF CAUTION, this setting is temporary, and must be re-entered whenever you restart the engine, as you will probably find out, cos mine just didnt run without it:)
The 'injector' function in settings menu is used to correct the injectors individually so the car can run in closed loop etc on the road, and should be adjusted when the tune is being done. You cant just change those settings and drive away happy.
This is what I found, and what I was told by a mech mate.
The primary and secondary settings you talk of are for RX7.
Ah ok. Yeah I'm starting to notice some discrepancies in this RX7 manual to what I see on mine. Like the 4 boost settings instead of 2. I will do as you've said once I put the injectors in. Thanks!
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for ?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for  >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate modern almost all cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
    • Let's be wary though, if cranking is so far off, what else isn't set right? Are the dead times set right, voltage compensation etc?   It definitely sounds like it's cranking fuel issues, and holding flat to the floor is shutting them down, but I'm with Duncan that if nothing was changed in the ECU at all, and then this started, I'd be more thinking a leaking injector.   Do as Duncan said, drop the oil and make sure it's not full of fuel.
    • It actually means give it less throttle.
    • Yeah if the goal is to drive something then modifying a car is a bad idea.
    • Wowee! She looks like a major handful out there Pete!
