Series 2 R33 headlights on a series 1.
Bonnet, centre grill all that needs changing? Or quarter panels and bumper? Or do none of the bolt holes line up?
Hey mate,
S2 Headlights, S2 Bonnet, S2 Grill, S2 Reo if your using the S2 front bar (or chop your S1 to suit)
The S1 front bar will fit but it will not line up properly under the headlights.
S1 and S2 quarter panels are the same so you wont need the change them.
Hope this helps,
Johno
ive got s2 headlights in my s1 gts,
yes there is a gap. had them put on after i crashed into the ass of someone else, whole front damaged. so everything got changed
but they got the wrong lights for me. didnt realise till a few months ago n the crash was about a year ago lol... so slow
pretty sure quater doesnt need changing
you sure about the quarter?
im not saying your wrong but i thought they were slightly different as the series 2 lights are bit more square?
Yep 100%, heres a pic of the car just after I did the S2 front end.. cant believe i did all that just to fit the TK front bar lol.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
