Ok, I've got no idea what has happened to my previous post...
Anyway, I've got a 11/97 Autech 260RS Stagea with genuine 73,000kms which I am currently wrecking. I was planning on doing an engine/manual gearbox conversion into my RS4, however have decided against it.
The 260RS shares most of the running gear with R33 GTR's eg. engine, gearbox, LSD, brakes etc.
RB26DETT engine comes complete with loom, ecu, manifolds, turbos but missing the afm's. The car was hit in the front, therfore the harmonic balancer was damaged. I have found a replacement one which will be included. The engine and gearbox are still in the car. - $4500
Twin Plate Exedy clutch, (only 1000kms old) - $1500
Manual gearbox - $1000
Brembo brakes complete with rotors and lines - $1900
Nismo front pipe (fits 260RS or R33 GTR) - $500
Used Hi Flow cat converter with 3" flanges - $80
New Trust Pillar Pod 60mm (fits R33) - $100
All prices are open to offers.
Parts are located in Adelaide (Aberfoyle Pk) however I'm happy to post interstate.
Please contact me via pm.
Cheers
Daniel
more info on the twin plate please!!!
pull type?
exactly what twin palte is it? carbon? hyper metal?
cheers
It's a pull type.
Receipt says it's a Exedy Twin Plate Hyper, sorry I don't have any more info or pics yet as it's still in the car. I'm hoping to have it out within the next few days.
Cheers
Daniel
Brembo calipers sold (pending payment)
Front and rear rotors and lines still available - $200 the lot.
Fronts are 324mm and rears 300mm.
Assume front pipe is 3"? Can you find out postage to Perth 6010? Cheers..
Yes the front pipe is 3".
Postage to Perth is $50.00.
Cheers
Daniel
Pair of factory air deflectors, these bolt on to the caster rods.
Excellent condition - $100 neg.
Edited by RSFour
interested in the engine.
do you know compression on the cylinders ?
would you provide some sort of warranty ?
please pm me mate :)
Any know issues with engine?
Do you know compression stats? Please pm back! Thx
PM's sent guys.
Brembo calipers and Nismo front pipe - sold.
Here's a pic of the Exedy clutch.
  • 3 weeks later...
Here are a some pics of the gearbox.
Also, for anyone interested the Exedy clutch is still available.
Cheers
Daniel
Yes
[/quote
I have the 260RS with N1 motor. Dont know what clutch this would have fron Autech ?What did
you pull out of yours when replaced ? Single plate no doubt ! About to put big dumps and Haltech
under it, and got to thinking the clutch to be a possible issue here ! Cheers
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
