biggest fkin motor you can fit +biggest fkin turbo you can fit = bigest fkin intercooler you can fit ???
sound fair enough ?
there is one rule that says the core volume should be 1.5 times times the engine capacity
or i can find you the formula that will work out exactly what the size the core should be for your HP but you need to know your airflow , how efficient your turbo is , what the ambient air temp is , and so on .
depends on what the car is going to be used for more than the turbo type. but judging by the size of the turbo I would guess it will be used for drag mostly. in that case a pretty big cooler will be the go. something around 150mm thick, trust, HKS, ARC, they're all good.
i know its not a t51r, but alot of ppl told me i would definatley need to upgrade my cooler, although it is doing a perfect job... i have a t04z making 600rwhp and its a hybrid 600x300x76 LOL... Kev @ Hyperflow was actually amazed when he saw how good it was working.
but yeh 100mm i reckon is plenty, ppl go stupidly big
Depends on how good the cooler is to... U can get a cheap china cooler like mine for $150 measuring 300*600*76 and it might be/most probably be shithouse for any turbo and boost level over 12psi lol but it looks hektik up front.
If you get a well designed cooler measuring the same it will do a better job at cooling the charged air.
I was reading HPI... Don't burn me, but it said a really good cooler that does a really good job at cooling the charged air kills the air flow to ur radiator which in turn takes ur intake temp down, but ur engine runs hotter so it all depends on how serious u r at how much power/life u want to be getting out of ur engine.
I have also heard thicker is better lol... Especially when it comes to intercoolers.
If u have gone to the effort and cost of building a tough RB30E or even more expensive RB30DET don't skimp on parts now. U may aswell get the best out of it.
Call somewhere who makes intercoolers.. Its their business to know and get the best out of their product. Call workshops with import drag cars.
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
