saw your up the back of advanced panel and paint today, dust shows on black lol.
and pm davidsdh on here i think he wants to sell his, dno if he will take 12.5 thou
I miss my baby!!! :no:
The S2 sounds good, what colour is it? Black is the win :)
Not too impressed with AutoWorx at all really. I spoke to the owner up there in regards to this about 2 months ago:
http://www.autoworx.com.au/site/index.php?...9&Itemid=64
And told him I was definately keen. He was getting it complianced so I couldn't hear the motor running or anything and it was up on a hoist. However the guy at AW reckoned it was putting out about 280rwhp with it's current running gear. The only thing that me and a few mates (who likely know more about cars than manufacturers do) could point out was that the side sils on the kit were slightly mismatched in colour and that the car had been resprayed hastily. The paint job itself was good, but you could see under the guards and so on where they hadn't sprayed the car was previously white.
Asked him to give me a call as soon as it came back from compliance and I'd take it for a drive and buy if I liked it, gave him my card. Never heard from him. Glad I didn't really, because I fkn live my GTR :rofl:
;) dilemma hey i wanted a rex and now i need to sell my baby. hopefully to u unless uve bought that other one :happy:
come have a look on Tuesday if u want it will be clean...for once.
Edited by Davidsdh
hahah ^ i already loved ur car the first time i saw the PIC. Looks hot
sometime i get pissed off with everythin. when someone wants a car he likes cant God just throw down some money lol
if i get enough cash i will come see it and buy it. Just waitin to see how much cash i get. My dad sent from overseas but the rate is farked so i am not sure how much i get. if i get more than i am expecting i will be in ur Driveway lol
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
