Hey, i was just in the market for a gps and i was looking at several different ones and since there are so many out there could someone tell me which is a good gps i should be looking at... And if anyone knows anyone whoz selling a GPS.. I really get confused with the roads in melbourne..
Sometimes i wonder how ppl know the entire city without a map...
Please let me know of any good gps which is not very expensive...
Thanks......
https://www.sau.com.au/forums/topic/281082-need-a-gps/
I have a Mio C520. It's not the best GPS in the World but it does the job. Sometimes the routes it recommends aren't the greatest as it doesn't take traffic conditions into account however you can subscribe to the traffic condtions report option for a fee and the GPS will make the appropriate calculations. The maps however are spot on and never had a problem with them like asking me to turn the wrong way down a one way street etc. The actual GPS location on the map is also excellent however it usually takes a little over a minute for the GPS to lock onto enough satellites to be accurate.
I've also found the battery life on the GPS is crap. Even after only owning it for about a year, the battery life was less than 1 hour so now I plug it into the cigarette lighter all the time.
It does have some pretty cool functions though such as one touch "home" and "work" options which will automatically point you in the right direction to get to either of those places from wherever you are. Also, the handsfree bluetooth speaker is great with the phone. It also has it's own phone book so as long as your phone is paired, you can just touch someone's name and it'll start dialing for you.
Having said all this though, I did get my GPS about 2 years ago so I assume technology has made them better.
https://www.sau.com.au/forums/topic/281082-need-a-gps/#findComment-4739541
TomTom is the best.. plus if you ever plan to travel / live overseas, it has the easiest access to foriegn maps.
Also has downloadable POI's for the map, so you can navigate to the nearest BP servo for that 98 octane goodness.
http://www.ozpoi.com
https://www.sau.com.au/forums/topic/281082-need-a-gps/#findComment-4740138
I use a trakmate tm350h which I find has several advantages:
1. Cheap, I got mine for $150 new, from a store, not ebay
2. Trakmate is an Australian based company. My previous GPS was an ebay special, and warranty service after sale was non-existent. My trakmate had a faulty speaker after 8 months, sent it to sydney on a tuesday, had it fixed and returned by thursday.
3. All the software is on the SD card, so you can easily run any software you like. I'm running IGo 8, have previous used tom tom and igo 7 on it as well
https://www.sau.com.au/forums/topic/281082-need-a-gps/#findComment-4739783
Personally I love TomTom however i've moved from TomTom to Sygic to Garmin in my opinion TomTom is the best, Sygic has shitty route calculating algorithms, and Garmin is crap interface, OK algorithms but have the most up-to-date maps (Unless you use TomTom 7) but they havent released that for Symbian...bastards
Personally my GPS is on my phone if your tech savvy it's cheap if your not....not so much by far I recomend TomTom but if your a cheap bastard like me somtimes you have to face the alternatives
https://www.sau.com.au/forums/topic/281082-need-a-gps/#findComment-4740099
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
