Item = Exedy Hyper Metal Single Plate Clutch
Location = Melbourne
Condition = Great condition (used for 3months)
Type = Pull Type (Will fit R33-R34 GTRs + R34 GTTs and Late Model R32 GTRs
Capacity = 250 - 370rwkw
Price = 1100 ONO
Hey guys!
Recently pulled off my Exedy Hyper Metal Single Plate Clutch off my r34 gtt due to updrading to a Twin Plate. this has defiently been a fantastic clutch. the perfect amount of play and engangement! very great feeling for the street and especially for those of you who like hard launches.
heres some info from nengun.
The EXEDY HYPER SINGLE CLUTCH is a new generation clutch set for light to moderately tuned vehicles up to 400 HP. The EXEDY Hyper Single Clutch is ideal for limited street driving and road circuit cars. The EXEDY Hyper Single Clutch has high torque capacity and a special lightweight design to reduce the clutch disc inertia.
LIGHT WEIGHT & LOW INERTIA DESIGN
- High friction coefficient, low wear, and a special heat resistant material (T5001) has been developed enabling clutch size to be reduced and have increased durability.
- Improved durability by strong small damper disc, especially re-designed for hyper single clutch.
- Disc inertia level is less than OEM clutch for improved shift response for fast gear changes, especially in racing applications.
DIAPHRAM SPRING TECHNOLOGY FOR LONG LIFE & HIGH EFFICIENCY
- Leading technology of clutch diaphragm spring and original design superior material using a special heat treatment process, which will result in a high durability level, and prevent heat deflection, loss of clamp load, and heavy pedal effort.
- Long life and improved clutch operation due to original design for hyper single clutch.
STRAP DRIVE TYPE PRESSURE PLATE FUNCTION
- Improved clutch disengagement. (Pressure plate is forcibly separated from facing surface by strap plate)
- Prevent no-disengagement problem caused by the heat deformation of pressure plate.
- Prevent the peculiar rattle noise of lug drive type clutch.
for those of you who are interested you can PM me here or please email me at "[email protected]"
alternatively my number is 0421691338.
THANKS!!!
Edited by Jap_Muscle
  • Replies 59
  • 3 weeks later...
  • 2 months later...
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
  • 1 month later...
  • 1 month later...
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
