Good stuff = it's practically the same suspension tech spec wise as the fabled unicorned monster stealth wagon. Bad stuff = this is a "one off concept car" $$$$$$$$$
And ...........it's missing one cylinder ffs! I mean really! How can that be good.
Very nice beach wagon all the same. For the night fishing trips of course. :)
They even ran once with toy dogs in the boot taped to the roll cage...
Joke was that someone at Volvo has misheard the name of the compertition and thought that it was the British Towing Car chanmpionships...
850 T5 was very popular with Police and company car users in the UK, as Volvo in those days allowed any engine in any trim level car, so it was possible to buy brand new a fairly cheap 850 T5 with wind up windows and a povo pack interior. Friend of mine in the leasing industry told me that most of these cars got through a first set of front tyres in about 4,000 miles. Once the owners had got that out of their system the second and third set went on at more normal intervals...
Great cars for their day, and even now...
I always have held a soft spot for OVLOVs and when I was on the market for a wagon I was seriously looking at V70's and XC70's, but then I test drove an M35 and the VOLVO was suddenly not even in the running, in fact no other wagon including A4 Audis and Merc's come close to M35 awesomeness.... errm
But while VOLVO's are the subject here is the meanest VOLVO wagon that ever was!
It's a '67 VOLVO amazon estate with a 600HP 3L Inline six from a VOLVO S80 up front stuck to the biggest snail I've seen on a non drag weapon.
Feast in it's glory!
Back in the GODS Robbie Frankovic (?) drove, as Dick Johnson and others described it, a "block of Sweedish flats".
It was pretty quick for a Volvo.
The other one I came across was a a rally car that was also very quick but not rugged enough.
ok, THAT is NICE!! where to buy? (haha).
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
