I hope its nothing serious with the engine, cos i've never had problems with it before. And i usually change the oil every 3months with motul.
is my engine healthy or oil maybe to thin?
hey mate,
I can see your fairly new to SAU, so welcome and enjoy your stay.
It could be one of many things, i would check:
1: Oil viscosity, if its too thin then chances are you engine is burning oil as well as petrol, here's a tip to remember though: Blue smoke = Oil, White smoke = Water, Black smoke = Petrol. So is there a light tinge to the smoke, or is just black black?
2: AFM (Air Flow Meter), on most skylines the AFM goes kaput after 30 - 40,000kms or so, so maybe change your over. If your AFM is broke, or faulty, your cars ECU guess's how much petrol to put in. Too much petrol = smoke.
3: Turbo (this is the worst one), just check to make sure your turbo isn't blown, a blown turbo can throw shit through the engine, and a worn out turbo will produce smoke out through your exhaust. If its the stock turbo and stock boost, you should be fine, as long as your car hasnt done between APPROXIMATELY 150 - 180,000kms.
Thats all i can think of at the moment, if i think of anything else i'll get back to ya.
Buckets out.
Nothing to do with oil (oil burns blue). The black is carbon particles as a result of the petrol not burning properly. The fuel/air mixture is rich, which is the protection that stops the engine pooping itself.
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
