I found this by pure chance and it has some usual features .
http://www.nzperformance.co.nz/store/garre...r/prod_189.html
I'm not sure which comp wheel this one has but will look around , Brett says that one of them uses the 76.2mm 52 trim GT37 compressor - same as the 3037 52T .
Possibilities in altered form , cheers A .
I'm pretty sure that's just a normal off the shelf item from Garrett.
Very overpriced too. They're at least a few hundred cheaper locally.
Who is Brett?
Have to agree, that looks a little old school and at 500hp rating isn't worth it. Still prefer the 3076 in anti surge configuration. The problem with these things is if nobody has tried it then what if you strap it on and it gives up the ghost at 250kws. Or ends up a laggy 3040 type turbo. That price looks a little high as suggested to, do yourself a favour and go to the ATP turbo site in the States. Got all my stuff there and is cheap. Then again, buy Australian and if you get it all from the one place maybe a discount is in order. As I said in my PM Adrian, just go with the .82 exhaust option and if you try this turbo, who knows, it may work out. I am not into external waste gates but then again as we've discussed the 63 housing with a 50mm waste gate should give you the best of both worlds. Still prefer the bigger housing though.
Brett from GCG I believe.
Edited by skylinecouple
Only relying on memory here...but doesn't the 2876 use a 52 trim 76mm comp wheel/housing - which may be the source of the compressor side of this setup.
Late Edit: Actually no, I just checked and the 2876 uses a 48 trim 76mm comp wheel and .70 comp housing - close but no cigar.
Edited by juggernaut1
No a GT3071R has a GT30 turbine (normal or cropped) with a 71.1mm 56T compressor wheel .
A GT3037S is a HKS marketed GT3076R having a GT30 turbine and a 76.2mm GT compressor , "S" in HKS's case means with the port shrouded compressor housing . The plain inlet snout ones are just called 3037 or GT3037 .
Doesn't matter anyway because that turbo in the above link is the wrong comp wheel style so no good .
Got the spies looking for either the right turbo or at least the right cartridge which appears to be available .
A .
So much choice. Well, look at the bright side, 10 years ago things were mighty different. To3 or To4, take your pick. Hey Adrian, what mods have you got so far ? Your not planning on cams or going for a rebuild are you ?
Just about to call you , hopefully talk this afternoon .
BTW I followed a link from an SR site to a HKS Japan site and this is what they say about their 3037 52T kit for S15 Silvias inc supposed dyno graph .
Now I know an S15 SR20DET is very different from an R33 RB25 and my guess is that an unopened late SR20 would be in a pretty soft state of tune . Can anyone who reads Japanese tell me whats been done to it please .
http://www.hks-power.co.jp/products/turbo/...waste_gtsp.html
Cheers A .
Funny you found this, I have been speaking with a reputable garrett turbo wholesaler in South Aus and was talking about the Garrett GT3076R.
They have 2 types that they sell, one is the GT3076R with anti surge compressor housing and .82 ext gate rear housing to suit, Trim is something like - 57 comp wheel, 55 turbine wheel.
The other is pretty much the same turbo with the 4" bell mouth compressor housing like the GT30R, with .82 ext rear housing - trim is 54.97 comp wheel, 53 rear turbine wheel.
Priced fairly differently, would there be an issue going with the GT3076R without the anti surge housing? all supporting mods looking for around 270-280rwkw.
Do a search, but I remember reading somewhere that some [note not all] users were experiencing surge.
I have the 100mm port shroud 'with all the supporting mods' and have not had any issues, but it depends on too many things to say that this will or will not happen.
Defining 'all supporting mods' is a key issue.
    • That's f**ked up. I'd guess it's more likely that you have an entire S13 subframe in there. Does it still have HICAS mounting points? Seeing as it is quite possible that yours is the only such converted car in the world, you'll probably struggle to find someone who can tell you from direct experience. 'Twere I you, I'd be looking for 4 stud Skyline rear brakes and convert back. At a minimum. Preferably go find all the stuff you need to put it back to 5 stud (assuming you're happy to change wheels) and upgrade to some decent brakes. You don't even need much stock stuff. Don't need calipers or rotors, as you can go fully aftermarket. Just needs hubs and the other bits and bobs that are different to what you have now.
    • The engine has nothing to do with it. The physical space behind the headlight is the limiting factor. And the height. The height of the NS70 is the same as stock. So the clamp bar across the top goes on nice. The battery tray is big enough for it to sit on. The X is for extra capacity - it has even more lead in it than the non-X NS70. Heavy f**ker. But it's not a track car, so I will suffer a couple of extra kg. In the case of the R34, maybe the physical space there is not as deep (forward-backward, not up down). Hence why they say the 60 is the biggest. But I would never trust a catalogue to tell me what will fit. I have the car. I have the existing battery. I have the tape measure. I have the dimensions of all the available batteries. I find the biggest box that will go in. (With the right terminals in the right places, of course).
    • Hello! I have been having a hard time finding the answer to this question… I have a R32 GTS-T Sedan than has been 4 lug swapped using S13 hubs, rotors, and brakes. The front has also been converted to S13 suspension.    When the swap was completed, the handbrake cables were never hooked up, as the S13 rear calipers are the “handbrake”, and not the typical drum on rotor that the R chassis are. Does anyone know handbrake cables that will work for this conversion? I’d like to not use a hydraulic handbrake and stick with the traditional cable style. My original thoughts were to go with S14 cables and try to make them work, since I’m pretty sure S13 cables will be too short.    Any help would be appreciated!
    • I did some research, considering you have a neo engine, how is that battery compatible? I checked centuries website and super cheap and says it's not compatible. Only this full size one is. https://www.centurybatteries.com.au/products/ns60-mf
    • No, lets be honest here. I went to Winton and did a track day, for all the mods and V8 power and craziness I posted up a time that a K24 stock motor Honda Accord can do on the same tyres (narrower, too) 250kw and learning how to drive the f**kin thing is the sweet spot.
