I know many of you tow your track cars to events and I was considering towing my S13 down to DECA in a few weeks just in case something goes wrong with it and I'm stuck 2hrs from home (the car is road reg'd but will have semi's on it and is starting to look a little track only)
Thing is, I'm not sure if I should risk it. My BA has a 1600kg tow pack (with an Auto) and the trailer weight plus the car would be closer to 1900kg's plus me, the missus, and some tools and so forth all on board. The car trailer in question is braked.
What are other peoples thoughts on this?
Dave I know you tow that datto behind a BA fairmont too but I didn't know if you had the 2300kg pack or not + the datto is a fair bit lighter than my Sil.
Cheers
https://www.sau.com.au/forums/topic/281330-towing-track-car-behind-ba/
Experience... 4wd style 10's of 1000's of towing km's in different vehicles with different weighted boats over different terrain. And the big no no ..using tow balls and bars to snatch recover vehicles oooops.. did i admit that.
It is not recommended and the manufacturer will not compensate you for any loss but in my experience you should have no problems at all as all these products are over engineered to avoid warranty claims etc..
Obviously you should pre check you tow bar attachments before you leave and ensure that the bolts to the chassis have no play in them.
Just keep in mind that what you are asking of the equipment and drive accordingly.
Lastly, maybe consider putting your missus up front in the BA with you instead of in the trailer etc...then that weight is not added on to the tow weight :)
Adz: did/does it have any special gear? Heavy duty tow pack or trans cooler?
racin8: yeah fair point about the weight diff, just dont wanna stuff the BA, those boxes aren't cheap =\
racin8 and Phatboy: hah ok ok you know I meant she'll be up front with me, just saying there will be more weight for the car to lug around
Anyone else wanna wade in on this?
No special tow gear on mine, just a tow ball :) I've used a double axel quite a few times to tow my C110's and not had any issues that I'm aware of. It's only the take off that's going to put strain on your car and for the most part of the drive you'll be sitting on 100-110 with no lights.
Right o guys, appreciate the input.
I think I might give it a go this time and see how the BA handles it.
I tend to play things safe so I like to at least have some idea of the risks etc.
I know that doesn't rule out the box breaking or something going wrong but at least I've done some ground work. Had the aut oserviced recently and the guy said it was in good nick so that's a good start.
Will check the tow pack component bolts as suggested also.
If you guys are heading to deca I'll see you there :P I'll be the guy nervously driving the BA Fairmont into town with the slow s13 on the back :)
i have on several occasions used my brothers AU falcon 4.0L with std tow pack to tow my S12 Gazelle and dual axle car trailor.
it's fine, but perhalps invest in a trans cooler if your car isnt fitted with one already!
Sorry I missed this for so long Dan.
Yeah the BA tows no worries. At a guess I'd say my Datto would be ~200kg lighter than the S13 but that's stuff all really. I've only got the 1600kg tow bar as well. I give the towbar and associated bits a once over ever time a use it which I know you'd do anyway.
You just need to give some thought how you position the car on the trailer, the trailer can pretty much take the entire weight of the car if you balance it right in the middle but they tend to tow better if you put a bit more weight on the back of the tow car. Towing cars is stressful business, you spend your entire trip checking mirrors and trailer tyres or loose tie downs etc. You'll be fine though.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
