turbosuk Posted July 31, 2009 Share Posted July 31, 2009 came home from work and my z tube was here so on it went Link to comment https://www.sau.com.au/forums/topic/281366-z-tube/ Share on other sites More sharing options...
MILLOS Posted July 31, 2009 Share Posted July 31, 2009 Nice, which one did you buy??? Link to comment https://www.sau.com.au/forums/topic/281366-z-tube/#findComment-4743335 Share on other sites More sharing options...
GTRsean Posted July 31, 2009 Share Posted July 31, 2009 MMMMMMMM carbon drooooollll. Very nice! Gonna get the airbox too?? Link to comment https://www.sau.com.au/forums/topic/281366-z-tube/#findComment-4743369 Share on other sites More sharing options...
g33k Posted July 31, 2009 Share Posted July 31, 2009 Can you link for the engine cover and carbon tube, i am buying it as soon as you post the link =) Link to comment https://www.sau.com.au/forums/topic/281366-z-tube/#findComment-4743429 Share on other sites More sharing options...
turbosuk Posted July 31, 2009 Author Share Posted July 31, 2009 g33k got it from www.thezstore.com the engine cover i got from ebay in usa cant remember as it was last year gtrsean havent seen a c/f air box as yet but if they make one i would think about it for sure Link to comment https://www.sau.com.au/forums/topic/281366-z-tube/#findComment-4743526 Share on other sites More sharing options...
g33k Posted August 1, 2009 Share Posted August 1, 2009 Thanks mate, found both. I think i might get one of these too mate, if you can find one - let me know, i can't figure out the brand: http://img378.imageshack.us/img378/9425/dsc01875nu3.jpg Link to comment https://www.sau.com.au/forums/topic/281366-z-tube/#findComment-4744182 Share on other sites More sharing options...
BLISTC Posted August 1, 2009 Share Posted August 1, 2009 (edited) Thanks mate, found both.I think i might get one of these too mate, if you can find one - let me know, i can't figure out the brand: http://img378.imageshack.us/img378/9425/dsc01875nu3.jpg thats a mishimoto intake. Edited August 1, 2009 by BLISTC Link to comment https://www.sau.com.au/forums/topic/281366-z-tube/#findComment-4744598 Share on other sites More sharing options...
rex2ce Posted August 2, 2009 Share Posted August 2, 2009 I give up , what is a Z Tube? Link to comment https://www.sau.com.au/forums/topic/281366-z-tube/#findComment-4745296 Share on other sites More sharing options...
n15m0 Posted August 2, 2009 Share Posted August 2, 2009 I give up , what is a Z Tube? The OEM 350z Intake pipe is commonly refered to as the Z Tube. It supposedly has less restriction compared to the OEM V35 intake pipe and hence this is one of the most common mods undertaken to supposedly gain a few extra kws and a more aggressive engine note at high revs. There are now a lot of different versions of the so called Z tube ie: polished, CF etc...all pretty much do the same thing. Link to comment https://www.sau.com.au/forums/topic/281366-z-tube/#findComment-4745570 Share on other sites More sharing options...
rex2ce Posted August 3, 2009 Share Posted August 3, 2009 Thanks for the info N15mo. Has anyone checked out the Squires remote turbo kits for these cars? Link to comment https://www.sau.com.au/forums/topic/281366-z-tube/#findComment-4746863 Share on other sites More sharing options...
rex2ce Posted August 3, 2009 Share Posted August 3, 2009 Check out this link http://www.ststurbo.com/ Link to comment https://www.sau.com.au/forums/topic/281366-z-tube/#findComment-4747626 Share on other sites More sharing options...
Oaksey Posted August 3, 2009 Share Posted August 3, 2009 Check out this link http://www.ststurbo.com/ I don't really get the point, seems to just be mounting a turbo towards the rear of the of the exhuast system where it is a little cooler but then you've got to have the plumbing all the way back to the front of the car? I'd think the air filter is likely to get more crap on it under the car and be more susceptible to damage too. Is the pipe back up to the front supposed to effectively replace an intercooler or something? Link to comment https://www.sau.com.au/forums/topic/281366-z-tube/#findComment-4747932 Share on other sites More sharing options...
rex2ce Posted August 4, 2009 Share Posted August 4, 2009 The point is that for a N/A car ,you dont have to fabricate expensive manifolding to mount the turbo/s on the engine . The remote turbo basically takes the place of the existing rear muffler. Yes, with the Squires method , they run lube and cooling pipes from the engine bay using engine oil and water pressure- lube only if you run a plain bearing turbo. Also, the compressed air is run under the car to the intake or a F/M intercooler first. If you read through their site, they claim little loss of thermal efficiency at the rear of the car. Another method of lubing the turbo is to buy a pump from these people www.tcsmicropumps.co.uk and have a self contained lube system in the boot of your car. They also say that if you keep boost below 8 psi, most cars can still use existing ECU, injectors and fuel pump. Another advantage of this system is stealth, your engine bay looks pretty stock. Last word, I am in no way connected with these people ,I just think their system is worthy of discussion on a N/A forum. Cheers Link to comment https://www.sau.com.au/forums/topic/281366-z-tube/#findComment-4749056 Share on other sites More sharing options...
