Thanks mate, found both.
I think i might get one of these too mate, if you can find one - let me know, i can't figure out the brand:
http://img378.imageshack.us/img378/9425/dsc01875nu3.jpg
thats a mishimoto intake.
Edited by BLISTC
https://www.sau.com.au/forums/topic/281366-z-tube/#findComment-4744598
I give up , what is a Z Tube?
The OEM 350z Intake pipe is commonly refered to as the Z Tube. It supposedly has less restriction compared to the OEM V35 intake pipe and hence this is one of the most common mods undertaken to supposedly gain a few extra kws and a more aggressive engine note at high revs.
There are now a lot of different versions of the so called Z tube ie: polished, CF etc...all pretty much do the same thing.
https://www.sau.com.au/forums/topic/281366-z-tube/#findComment-4745570
Check out this link http://www.ststurbo.com/
I don't really get the point, seems to just be mounting a turbo towards the rear of the of the exhuast system where it is a little cooler but then you've got to have the plumbing all the way back to the front of the car?
I'd think the air filter is likely to get more crap on it under the car and be more susceptible to damage too.
Is the pipe back up to the front supposed to effectively replace an intercooler or something?
https://www.sau.com.au/forums/topic/281366-z-tube/#findComment-4747932
The point is that for a N/A car ,you dont have to fabricate expensive manifolding to mount the turbo/s on the engine . The remote turbo basically takes the place of the existing rear muffler. Yes, with the Squires method , they run lube and cooling pipes from the engine bay using engine oil and water pressure- lube only if you run a plain bearing turbo. Also, the compressed air is run under the car to the intake or a F/M intercooler first. If you read through their site, they claim little loss of thermal efficiency at the rear of the car.
Another method of lubing the turbo is to buy a pump from these people www.tcsmicropumps.co.uk and have a self contained lube system in the boot of your car.
They also say that if you keep boost below 8 psi, most cars can still use existing ECU, injectors and fuel pump.
Another advantage of this system is stealth, your engine bay looks pretty stock.
Last word, I am in no way connected with these people ,I just think their system is worthy of discussion on a N/A forum.
Cheers
https://www.sau.com.au/forums/topic/281366-z-tube/#findComment-4749056
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
    • You reckon? I have to disagree. Notwithstanding that at some point we may all be forced to do this to our cars if we want to keep driving them, there is absolutely nothing about an electric-converted-previously-IC-car that is ever good. EVs that are built by OEMs on platforms that were originally IC already suck, let alone the shitty outcomes that result from doing it as a retro to something that was actually built as an IC car. This is because the platform really needs to be designed to house the battery in a useful place (ie, down as low as possible) and the motors are properly located relative to the wheels that they have to drive. Converted platforms already suck at this. But when you try to shove sufficient battery capacity into a previously IC car, you can't put it down on/in the floor, because that space doesn't exist. You can't find enough space where the fuel tank used to be (if it is an inboard fuel tank) and you don't want to hang it out behind the rear axle line if you had a rear fuel tank. And there's not enough space in the tunnel if you still want to use it for anything remotely like what it was originally used for. The engine bay is too big for a motor, and you'd really prefer that the motor for the rear wheels wasn't in the front engine bay anyway. And there's not enough room where the diff was for a proper man-sized E motor. And then.... there is the complete lack of soul and emotion that is provided by EVs. There are some cracking restomods out there. Like the Alfaholics GTA thingo. But it is petrol powered. Look at the alternative EV version of a GTA restomod by Totem. it is jaw droppingly beautiful. But by all reports is is objectively awful to drive, despite having 600 HP or something, simply because there is nothing there. It sounds like a sewing machine or a leaf blower. It should scream and wail and make the hairs on your neck stand up. Oh, and it's 1500 bloody kg in a car that was <900kg when new. GTRs are heavy enough as it is without pushing them up to 2tonnes worth of pork.
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
