My R32 GTR has a small issue where there is quite considerable vibration through the car when its idling.. The steering wheel wobbles and vibrates, and if i have the windows half way down they rattle!! The engine itself is motionless and seems to idle smoothly.
When driving there are NO vibrations, and when you free rev the car to around 1300rpm the vibration stops.. The normal idle is between 1,000-1,100rpm.
Some info about the car would be helpful so here is the basics:
Internally standard engine (AFAIK, was overhauled just before i bought it) apart from ARP head studs.
Aftermarket Exhaust
Coilovers (rock hard)
Injectors (maybe causing the trouble??)
Fuel pump
Power FC
Te rest of the parts shouldn't have anything to do with this issue
There is also a faint noise on idle that sounds strange, nothing that you can really explain. My guess it is to do with one of the drive belts or pulleys
So my question is, has anyone else had the vibration problem in a Skyline?
https://www.sau.com.au/forums/topic/281377-vibrations-through-car-on-idle/
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
