  • Replies 286
Posted Images
Hey... whats the latest time you guys gonna leave Yatala? I'll probably be able to make it there around 1030. Worse comes I'll call someone up and find out where you guys are heading.
Going on past years we usually end up waiting for groups to arrive. Aiming for a 10am cruise depart, but it will prob be more like 10:15-10:30am.
doesnt look like ill be able to make it after all :P
car still have that misfire problem, wont go over 2000revs, mechanic was 100% sure it was the cam angle sensor, cost me 600 $$ and it didnt fix shit. now he recons its a problem with my alternator... wtf. Highly highly dout thatll be done for sunday. next year ill come!
doesnt look like ill be able to make it after all :)
sounds like you need a new mechanic..
had the same problem bud, upgrade to Splitfire coil packs and hey presto, problem fixed.
just make sure you get the right ones for your engine. rb20 / rb25
I've got 2 mates that would like to come along.
One in a heavily tuned 280ZX. Technically has some RB power... has 6x RB30 throttle bodies... and the gearbox has some DR30 parts in it.
And one in an N/A S13 (but he might bring his R30 if it decides to run okay on that day).
sorry im trying to do this on a mobile phone.... it wouldn't let me post with a quote.... anyways, has anyone answered Garrat's post?
I have emailed Wagamama but no reply.... just want to know if I can come on this cruise?
I have a heavily worked 1981 nissan 280ZX track day car, its very tidy with 6x RB30 throttle bodies & DR30 gear set.
i say bring it anyway. but it's a well known fact that what i say doesn't matter haha
The rules for cruise attendance in the past have been simple.
A. Club member
B. skyline owner
C. RB powered
To qualify for the cruise one had to meet at least 2 of those points.
huh - what? are you trying to be funny? did i miss something?
2 out of 3 rule is
a. Nissan
b. Skyline
c. RB powered
Noel's rule is slightly easier for people to attention imo. You can sign up on the day itself and automatically you got that 1 out of 3!
Oh yea. That means anyone that owns a Nissan and dont mind paying for the membership fees can join in! :)
Edited by Brandon
Sorry mate haven't seen any email come through.
PM Sent.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
