Item: Nissan R33 GTS-t skyline
Website: boost & nissansilvia.com
Item Condition: Great
Reason for Selling: don't like my chances of getting a dirt bike in the back of it
Price and Payment Conditions: 13,000 ono or swaps
Extra Info: mods are: Front mount cooler, full 3in exhaust with split bump pipe, HKS mushroom pod in custom air box, 50mm Alloy radiator, silicone radiator hoses, turbosmart t-piece boost controller, 400r front and rear bars, gtr side skirts, drift lip yet to be fitted, Momo race steering wheel, razo gear knob, blow off valve, apexi turbo timer, autometer boost gauge, heavy duty brass button clutch, 2 way kaaz diff, tanabe shocks, lowered pedders springs, front strut brace, cadince stereo, working sunroof, the car comes with with a either a set of white terroritys or a set of 18in works that are being re rolled and polished and the moment or can have both.
Contact Details: Reply or PM me on here or send me an sms on 0424697536
Also has had a new gates racing timing belt and drive beltsas well as a new water pump and major service
Just fitted a RB25 hi flow turbo this weekend good great :drool:
cheers Daniel
Pictures: http://www.boostcruising.com/forums/index....howtopic=441126
https://www.sau.com.au/forums/topic/281387-black-r33-gts-t/
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
