I dont care what anybody else says/thinks, BOVs are a performance mod. A correctly adjusted BOV will reduce lag between gear changes, you cant adjust the stock unit, which is only designed for stock boost.
Bottom line, it decreases lag, and will protect the turbo better than a stock one - so is a performance mod. I noticed a definate improvement when I fitted mine and correctly adjusted it.
If you dont want to be defected, just make sure you plumb it back.
https://www.sau.com.au/forums/topic/28140-should-i-bother/#findComment-586440
Maybe but not the blitz one.
I had one on my car for 6 months, and now that i took it off it drives so much smoother and doesent cough and splutter between gear changes anymore
Nickr33
Be prepared for stall, running rich and big flames out your exhaust with the blitz unit.
https://www.sau.com.au/forums/topic/28140-should-i-bother/#findComment-587160
mmmm....won't bother then, my 3"dump pipe and high flow cat are on there way soon... might just save up for the cat back and muffler.
Quick question (maybe a stupid one)...can I install the 3" dump pipe and cat and just leave it stock from the cat back or does it need to be 3" all the way?
https://www.sau.com.au/forums/topic/28140-should-i-bother/#findComment-587201
INASNT, did you try adjusting the blitz one?  Seems pretty bizarre that a reputable jap company would produce rubbish.... just goes to show I suppose:)
I ***ed with it for 6 months with ever setting possible and it dodnt do shit, even ice performance who are building my car told me to piss it off
https://www.sau.com.au/forums/topic/28140-should-i-bother/#findComment-587844
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
