Hey forum I am having an issue with my car overheating and was wondering if anyone can give theories why. I never had heating issues with my normal radiator with clutch fan, but I took it out to install an aluminum dual core I got on a deal. Now the car overheats during normal driving in the daytime. It overheats to the point where hot water bubbles out of the overflow bottle and the stock temp gauge is right below the mark before the H on the gauge.. I have driven it extremely hard in the night time and it didn't overheat, or I just have not driven it long enough, but I think I did as it was driven hard. It just seems to overheat in the daytime under normal driving conditions. I have a 16" electric fan attached to the radiator for cooling without shroud. Can anyone give suggestions as to why it is overheating now with a bigger radiator installed?
https://www.sau.com.au/forums/topic/281403-overheating-heating-issue-r33/
You may have a air lock in the system.... Just a thought does happen if they are not filled correctly...
Try this:
Start your engine, but leave the radiator cap off so the pressure doesn't build up.
Let the engine run until it reaches its operating temperature.
Turn on your heater and set the temperature control to hot. This will circulate the coolant and any air in the heater lines and core.
Check the level of the coolant. You may find that the level has gone down some. How did that happen? The air trapped in the radiator kept the level artificially high; when this air was released, it opened up more space in the radiator, and allowed more antifreeze into the system. Add more water and antifreeze, in the same 50/50 ratio, to fill the space left by the bled-out air.
As the air bleeds out, the coolant may bubble and spit from the opening on top of the radiator. Use caution--that coolant is hot.
If this does not work check thermostat but i would say thats ur problem.
depending on the front mount (if you have one) you could have it restricting flow to the radiator, some aftermarket ones due tend to create a host of cooling problems especially on the track, but go through the basics first, check coolant level and look for leaks/blockages within the radiator...
:O
Just had my dual core installed, retained the stock shroud and my temps are about 13-15 degrees lower at all times...
end thread.
Edited by gunmetalgrey
gunmetalgrey was the first person to pic up the problem. without the shroud the fan isn't work properly. it is probably only working at 50%, if that. most of the cooling comes from the ends of the fan blades as they are traveling faster then the centre of the fan (same rpm, but at a faster speed). without a proper shroud the fan can just suck air from around the outside of the radiator. personally i, and many others, think that the stock clutch fan works better than most thermos.
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
