Hey forum I am having an issue with my car overheating and was wondering if anyone can give theories why. I never had heating issues with my normal radiator with clutch fan, but I took it out to install an aluminum dual core I got on a deal. Now the car overheats during normal driving in the daytime. It overheats to the point where hot water bubbles out of the overflow bottle and the stock temp gauge is right below the mark before the H on the gauge.. I have driven it extremely hard in the night time and it didn't overheat, or I just have not driven it long enough, but I think I did as it was driven hard. It just seems to overheat in the daytime under normal driving conditions. I have a 16" electric fan attached to the radiator for cooling without shroud. Can anyone give suggestions as to why it is overheating now with a bigger radiator installed?
https://www.sau.com.au/forums/topic/281403-overheating-heating-issue-r33/
You may have a air lock in the system.... Just a thought does happen if they are not filled correctly...
Try this:
Start your engine, but leave the radiator cap off so the pressure doesn't build up.
Let the engine run until it reaches its operating temperature.
Turn on your heater and set the temperature control to hot. This will circulate the coolant and any air in the heater lines and core.
Check the level of the coolant. You may find that the level has gone down some. How did that happen? The air trapped in the radiator kept the level artificially high; when this air was released, it opened up more space in the radiator, and allowed more antifreeze into the system. Add more water and antifreeze, in the same 50/50 ratio, to fill the space left by the bled-out air.
As the air bleeds out, the coolant may bubble and spit from the opening on top of the radiator. Use caution--that coolant is hot.
If this does not work check thermostat but i would say thats ur problem.
depending on the front mount (if you have one) you could have it restricting flow to the radiator, some aftermarket ones due tend to create a host of cooling problems especially on the track, but go through the basics first, check coolant level and look for leaks/blockages within the radiator...
:O
Just had my dual core installed, retained the stock shroud and my temps are about 13-15 degrees lower at all times...
end thread.
Edited by gunmetalgrey
gunmetalgrey was the first person to pic up the problem. without the shroud the fan isn't work properly. it is probably only working at 50%, if that. most of the cooling comes from the ends of the fan blades as they are traveling faster then the centre of the fan (same rpm, but at a faster speed). without a proper shroud the fan can just suck air from around the outside of the radiator. personally i, and many others, think that the stock clutch fan works better than most thermos.
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
