Originally posted by Ryan D
R33 GTS4
2.5l, non turbo, all wheel drive, and sexy as hell.
cant go wrong
Yeah thats what i had heard the 2.5 in a 32 is lethal where as in the 33 its powerful but is held back by weight ratios.
But i dunno im just a kid, lol, keep the opionions coming
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-585825
The fastest N/A's down the strip I know of are actually the R32 GTS25's, they come out factory with 142kw at the flywheel. With a bit of work they can run low 15's.
Even though the type S R33 tend to make a little bit more power(147), the extra weight of the R33 works against them.
But give me a R33 any day :P
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-585957
umm people are already buying them and putting them in storage in japan. when the car is 15 years old to the day u can bring it in, but make sure u research its not that simple, u need to apply for permission to import that vehicle and a whole range of other things.
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-586053
Let a company like prestige motorsport worry bout all that for you if you choose to import, i got the R32 gts25, its a nice car, my auto box holds it back but thats to change in the future. Got the 2.5ltr goodness and the lighter shell, more room in a r33, bigger backseat etc, more spacious, but the r32 just looks mean and ready to go.
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-586065
The R33 GTS25 is quicker than the R32 GTS.
Last year at the drags a guy with a R32 2LGTS manual was running high 16,s for the 1/4 mile, that was with air filter,extractors and 2 1/4" exhaust. A R33 GTS25 will run high 16's stock.
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-587424
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
