Originally posted by Ryan D
R33 GTS4
2.5l, non turbo, all wheel drive, and sexy as hell.
cant go wrong
Yeah thats what i had heard the 2.5 in a 32 is lethal where as in the 33 its powerful but is held back by weight ratios.
But i dunno im just a kid, lol, keep the opionions coming
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-585825
The fastest N/A's down the strip I know of are actually the R32 GTS25's, they come out factory with 142kw at the flywheel. With a bit of work they can run low 15's.
Even though the type S R33 tend to make a little bit more power(147), the extra weight of the R33 works against them.
But give me a R33 any day :P
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-585957
umm people are already buying them and putting them in storage in japan. when the car is 15 years old to the day u can bring it in, but make sure u research its not that simple, u need to apply for permission to import that vehicle and a whole range of other things.
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-586053
Let a company like prestige motorsport worry bout all that for you if you choose to import, i got the R32 gts25, its a nice car, my auto box holds it back but thats to change in the future. Got the 2.5ltr goodness and the lighter shell, more room in a r33, bigger backseat etc, more spacious, but the r32 just looks mean and ready to go.
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-586065
The R33 GTS25 is quicker than the R32 GTS.
Last year at the drags a guy with a R32 2LGTS manual was running high 16,s for the 1/4 mile, that was with air filter,extractors and 2 1/4" exhaust. A R33 GTS25 will run high 16's stock.
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-587424
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
