just got a quote to fix up my suspension and steering.
$2,100!
bloody hell. has anyone got a good steering box for less than $800?? that's the main stinger.
Hi
Where are you located? The local wreckers have a few more Skylines than usual.
JohnH
https://www.sau.com.au/forums/topic/281428-oh-snap/#findComment-4743661
oh wow. i need a few other little bits and pieces too maybe. what models are there?
im in brisbane.
That's too far to drive - especially with dodgy steering (I'm in Melbourne).
By the way, it might be a good idea to get an independent second opinion on the steering problems - just to make sure before you start spending the $$$$.
cheers,
JohnH
https://www.sau.com.au/forums/topic/281428-oh-snap/#findComment-4743716
if you have a power steering box, take some pics and send em my way...
I know of a few reco ones, and a few others getting put together
Steering Rebuilds Australia in melbourne quote $495 full rebuild and includes the $295 genuine nissan rebuild kit (gears, bearings seals etc)
theres another fella in nsw but he's hard to track down, about $350 full rebuild
https://www.sau.com.au/forums/topic/281428-oh-snap/#findComment-4743899
    • Yeah, well, it's not as though anyone is ever going to buy one of those noisy f**kers and put it into a new installation when there are better pumps that are near silent for less money from Ti.
    • I'd suggest having the engine builder listen to it, especially if they assembled it, and minimise how much you run it in the meantime. It may have a serious issue like a big end bearing from the description and I assume the rebuild was not cheap
    • Quite right, typing without checking, it is an 023 which was effectively the replacement for 040 (not that I could find either of them on the Bosch motorsport AU site), and it has a mesh inlet at the bottom of the pump rather than a separate filter
    • Hmm. I should have thought of the clutch bleeding issue. It should be #1 thought for "can't select gears". As to "sounds like the top".....have you actually gone out with the stethoscope and tried to pin it down any more than that? And, buy or borrow a timing light, and set the timing properly.
    • I donโ€™t really have any ideas how to set the timing on the CAS ๐Ÿ˜‚, sounds like the top, sounds like it maybe misfiring as well as ticking,ย  got the box sorted ๐Ÿ˜Œ, must of been a air bubble on the clutch side
ร—
ร—
