I have an IHI twin turbo set off two different WRX engines for an rb25/30 build im doing for my drift car. I was told by the guy who was running it he was making just shy of 300rwkw on an rb25 with fairly good response. He also told me they would in theory be even more responsive on an rb25/30 because of the 3L bottom end and because I’m using a 6 throttle RB26 inlet manifold. The manifolds that came with the head and turbos are way too high and so I asked 6boost to make me some new ones. He then told me -
Do you want to do this to be different?? Or to make power, or think it'll spool earlier?? As my best advise would be to sell it and go single, GT35 will make more power and out spool it, look neater and be less hassle, however if you must have twin manifolds, they would be $1400inc and take 1 week to build for you.
And I said -
hi mate,
I was told these came off a built rb25 and made just shy of 300rwkw. I was also told, because I’m putting them on a RB25/30 they will spool faster then on the RB25. I’m only after a solid 300rwkw. I’ve always liked the idea of twins, (not trying to be different) but it was always too much hassle and money to go that way. I was going to go the GT35 and then I found the head on eBay for real cheap. The turbo's are in immaculate condition (almost new). I’m also putting a 6-throttle RB26 inlet manifold on the NEO head to improve response.
Do you think these ideas and info sound plausible?
And he said -
The twins will definitely spool slower than a single GT35. Even on an RB26, a GT35 with .82 spool FASTER than the STOCK twins, and makes more power than the biggest bolt on style turbo's the HKS 25/40's, which it out spools these by 1500rpm. The old myth that twins spool earlier is from 10 years ago when single turbo technology was in the 70's still, yet smaller style T28 stuff had been vastly improved. If you’re after response, IMO, the worst thing you could do it fit twins.
Same goes for the 6 throttle intake manifold. They lose about 500rpm of spool; Zoom back to back tested it years ago and found they lost massive midrange. I have found the same thing comparing a GReddy style RB25 intake to a stock intake with top half style plenum. The short runners of either a GReddy or RB26 manifold is what kills the bottom end torque and hence spool. The best possible spool combination you could possibly fit to this engine is the stock lower runners, a Plazmaman top half plenum, and a GT35 with .82 rear. With the VCT connected, you should have 20psi by 3400rpm, and make 300rwkw on 16-18psi, if the engine is built with rods and pistons, you'll make 350-380rwkw on 20-22psi pump fuel no stress at all.
So can some one pleas clarify this for me?? And please tell me what is true.
post-64498-1249094052_thumb.jpgpost-64498-1249094061_thumb.jpgpost-64498-1249094084_thumb.jpg[atta
chment=237597:5.jpg]
https://www.sau.com.au/forums/topic/281440-twin-or-single-please-help/
If it was making '300rwkw' on a RB25 it would have been on around 3500rpm mark give/take (IMO possibly close to the 4000rpm marker)
Now add in two of them, and only another 500cc - you are not going to see it any better than at least 4500-5000rpm IMO.
Its all pretty much guess work of course because of the unknown spec of the turbos (you other thread said they were hi-flowed?)
Basically forget whatever he was telling you, most of what you have posted above is wrong mate.
2540's are NOT the biggest bolt on's, in fact they are a horrid horrid turbo that HKS should never have sold.
Also im not really sure where you say a 6 T/B setup hurts spool and performance... first i've heard of it.
At the end of the day - two simple questions for you.
How much power do you want?
What is the budget for new turbos?
Answer that - the rest is easy for everyone.
The way i read what he said the twin system was making the 300, not a single.
Extra capacity will make the thing spool faster no doubt, but since you dont know how they spool now this doesnt tell you much.
If it were me and my money;
- I sort of like the idea of being a bit different but i'd only try this setup IF
1. you can verify that the turbos are a sensible size
2. you use the manifold you have. I dont see that buying this setup is worth it if you just going to throw the manifold away
- the 26 manifold/throttles probably arent worth the extra cost for only 300kw
- single vs twin is largely a wank - as long as you get something that's sized correctly for your power goal you'll be happy.
That guys style of discussion sets off alarms for me.
I dread to think what that er collection would weigh let alone how it would fit in an engine bay - sheesh .
Firstly WRX turbos are designed to work on a 2L four with a badly screwed up firing order in relation to the exhaust headers layout . The boxershi - er pistons motor fires the adjacent cylinders in each bank before going to the other bank and because the headers go two into one just down stream of each head the exhaust pulsing is all wrong . This is why Rexes make that stupid off cadence "Boxer Burble" especially when Roger Racer pinches the stink pipe off thye side of the house and makes a automotive farter out of it ...
People here are getting 300 Kw out of a GT3076R on - wait for it - the factory RB25 exhaust manifold .
I don't agree with the less torque / "spool" with the GTR inlet system . What they do is let pressure rise very quickly in the cylinders when you bang them open and if there is enough fuel hosed it to keep the AFR's about right then theres a bit more exhaust being produced to help drive the turbo/s into boost . Throttle response and turbine response are not the same thing but they can be better match with a bit of thought put into it .
I find it hard to be objective about the drift world and I wouldn't waste a Skyline or an RB doing it .
Better I think with an AE86 Sprinter or even an old T18 because they are lighter in the bum as well as overall , sort of narrow track to wheelbase ratio and maybe better to steer with the throttle .
I'm sure 6Boost will take your money if you want him to but I reckon it's good money after bad .
Start again , cheers A .
hrm true - if he was though, just looking @ the sheer size of the comp housing and wheels... i can't see how its going to be all that responsive :down:
Everyone gauges 'response' differently. Some are fine with power coming on @ 5000rpm as it makes them feel like they have a fast car :)
Just one thing about the GTR intake/ITB's set up. It's a short runner intake design and is better at high end flow than low end torque. The ITB's produce better throttle response, not better low end power. Their is a world of difference between those two and most people mistakenly consider them one and the same.
And I said -
hi mate,
And he said -
Same goes for the 6 throttle intake manifold. They lose about 500rpm of spool; Zoom back to back tested it years ago and found they lost massive midrange. I have found the same thing comparing a GReddy style RB25 intake to a stock intake with top half style plenum. The short runners of either a GReddy or RB26 manifold is what kills the bottom end torque and hence spool. The best possible spool combination you could possibly fit to this engine is the stock lower runners, a Plazmaman top half plenum, and a GT35 with .82 rear. With the VCT connected, you should have 20psiby 3400rpm, and make 300rwkw on 16-18psi, if the engine is built with rods and pistons, you'll make 350-380rwkw on 20-22psi pump fuel no stress at all.
Hmmmm... not likely
lets pluck some numbers
Edited by URAS
Hmmmm... not likely
errm.. on a 25/30 with VCT i think 20psi by 3400 isn't too far off the mark..... the power figures he is quoting are also pretty consistant with the other results I have seen on 35r's....
I think that someone who designs and builds manifolds every day might know what he is talking about.
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
