Everytime I press the cigarette lighter in it blows the fuse , does anyone know why this would be so ?
I've checked the wireing as far as I can and it appears good and unmolested.the fuse is 15amp and correct according to the diagram on the fuse box lid.
https://www.sau.com.au/forums/topic/281471-shorting-cigarette-lighter/
Also check wiring for other stuff. The lighter wire is a good one that everyone picks on for anything that needs accessory power turbo timers, gauges, boost controllers etc
Thanks for that, I've taken out the gearstick surround panel and the stereo/ a/c unit and as far as I can see nothing has been run of the lighter wire or the cable it goes into, the only non stock thing in the car is the alarm and I have no idea how this was set up.
Can the alarm cable be picked up at the fuse box or elsewhere, I'm a dummy when it comes to wireing, if it isn't obvious I realy don't know where to start.
2LV8ETRPosted Yesterday, 05:05 PM Try a different lighter in the socket and see what happens.
The lighter itself may be cactus and is creating a dead short instead of heating the element.
Thanks mate I'll give that a go, I've got an led one that came with a Fast Fours about 10 zillion years ago still in it's packing and kept under the --it'll come in usefull sometime ??
Edited by BASHO
Take everything needed for the alarm from the ignition wiring harness under the steering column.
Everything you'll need is there and it's only a short distance to the central locking unit behind the drivers kick panel if you are installing CL.
Thanks guys ,
sorted , I renewed the fuse-again- and tried a plug in 12v vac I had lying around and it worked fine so socket wasn'tfaulty, so on to the Hot 4's freeby, which actualy didn't fit the socket, so I stripped the guts out of it and put them in the old one and it worked fine, I couldn't resist the flashing LEDS and chrome golf ball looking push thingo so I put that on for good measure , now the car feels much faster, he he.
Then I realised I'd given up smoking 3 years ago.
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
