Everytime I press the cigarette lighter in it blows the fuse , does anyone know why this would be so ?
I've checked the wireing as far as I can and it appears good and unmolested.the fuse is 15amp and correct according to the diagram on the fuse box lid.
https://www.sau.com.au/forums/topic/281471-shorting-cigarette-lighter/
Also check wiring for other stuff. The lighter wire is a good one that everyone picks on for anything that needs accessory power turbo timers, gauges, boost controllers etc
Thanks for that, I've taken out the gearstick surround panel and the stereo/ a/c unit and as far as I can see nothing has been run of the lighter wire or the cable it goes into, the only non stock thing in the car is the alarm and I have no idea how this was set up.
Can the alarm cable be picked up at the fuse box or elsewhere, I'm a dummy when it comes to wireing, if it isn't obvious I realy don't know where to start.
2LV8ETRPosted Yesterday, 05:05 PM Try a different lighter in the socket and see what happens.
The lighter itself may be cactus and is creating a dead short instead of heating the element.
Thanks mate I'll give that a go, I've got an led one that came with a Fast Fours about 10 zillion years ago still in it's packing and kept under the --it'll come in usefull sometime ??
Edited by BASHO
Take everything needed for the alarm from the ignition wiring harness under the steering column.
Everything you'll need is there and it's only a short distance to the central locking unit behind the drivers kick panel if you are installing CL.
Thanks guys ,
sorted , I renewed the fuse-again- and tried a plug in 12v vac I had lying around and it worked fine so socket wasn'tfaulty, so on to the Hot 4's freeby, which actualy didn't fit the socket, so I stripped the guts out of it and put them in the old one and it worked fine, I couldn't resist the flashing LEDS and chrome golf ball looking push thingo so I put that on for good measure , now the car feels much faster, he he.
Then I realised I'd given up smoking 3 years ago.
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
