I have heard notional figures of AU$45k for the transmission and AU$75k for the engine (new prices) regardless of IF they can be purchased. Not that you would buy a crate motor for $75k (if you could) you would instead build something better etc.
If you have need of one and can get it cheap, grab it!
LSX-438, happen to know what a set of brakes are? Endless do a sweet adaptor kit to fit them to an older series R32/33/34 GTR.
If you were to ask for a complete OEM Nissan pad and rotor swap, i believe it will be in the vicinity of $8000 to $10,000 (and that doesnt include calipers nor lines). A full brake system would surely be $20k or more. This is for ordinary cast iron & cross drilled rotors mind you. However most people are buying aftermarket pads and rotors, which are about half these prices (and better spec too). If you have an OEM motor/gearbox/brake system and want to offload it, PM me please.
I wish...
I asked the question to see if it would be worth buying the R35 calipers themselves along with some Endless adaptors and some aftermarket discs. That would be a sweet stopping package for a 200kg lighter older series GTR (like mine).
Sorry, off topic.
So if something like this was to be wrecked you might be interested in some parts?
expensive.. weeeeee
Hey idiot, leave the stupid comments out of the thread - their not welcome here.
Judging by the posts it looks as though you're trying to get your post count up - typical. You're not contributing anything at all,
eg
Exhibit 1
Exhibit 2
Exhibit 3
Don't reply with shit that doesn't contribute!!
good luck with trying to get it over here mate....im sure if you did, youd basically be able to name your price on anything in it....plus the running gear would be an awesome retro fit into something like a 240/260z :P
yes we looked at buying it must be 6 months ago or more now. hopefully it's been well stored and is still in good condition. I thought it sold on ebay US?
the stuff is only worth what someone is willing to pay. but consider you could buy a wreck in japan for around $40K (or less) and import that as a parts car and I'd consider very carefully before you spend any decent time or money bringing it out here hoping to get $100K+ for all the bits.... JDM wreck would also be more desirable as it's RHD. also, that car was pretty heavily crashed, there have been a few wrecks around with less damage going for pretty fair money.
Oh my young friend.... if only you knew how difficult that task would be. You'd swear these 35's have a brain of their own, they know what you're doing to them, even without a battery in them! lol
good luck with trying to get it over here mate....im sure if you did, youd basically be able to name your price on anything in it....plus the running gear would be an awesome retro fit into something like a 240/260z :)
someone do that please!!!
i couldn't see that black wreck fetching more than 25k
are you in the states? if not id get someone who has half a mechanical brain to check it out, and id assume with the new GTR a multimeter would come in handy to check all the electrics.
Being done ...
I might just bring the engine, transmission and brakes over and see how things go from there. It's all that's really useful on the black one.
Dude. Just put a price on it & see what happens. No-one here will put there hand up unless you put your balls on the wall & see what happens. Looks like a gamble to me. These things are that fast I dont think it will be long before we see a few local ones on the market like that (of course I hope not - but lets wait & see)
20 years to catch up? Hmmm. Didnt see Porsche at Bathurst 20 years ago. (But I was too busy drag racing Holdens back then to care anyway!!!)
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
