Value Of R35 Engine And Transmission
[200]
 Share
Hi,
I am interested if anyone could put a value on a 2009 R35 engine and transmission with about 3,000 miles on the dash?
Its my understanding that it cannot be purchased from a dealership as such correct?
Cheers
I have heard notional figures of AU$45k for the transmission and AU$75k for the engine (new prices) regardless of IF they can be purchased. Not that you would buy a crate motor for $75k (if you could) you would instead build something better etc.
If you have need of one and can get it cheap, grab it!
LSX-438, happen to know what a set of brakes are? Endless do a sweet adaptor kit to fit them to an older series R32/33/34 GTR.
If you were to ask for a complete OEM Nissan pad and rotor swap, i believe it will be in the vicinity of $8000 to $10,000 (and that doesnt include calipers nor lines). A full brake system would surely be $20k or more. This is for ordinary cast iron & cross drilled rotors mind you. However most people are buying aftermarket pads and rotors, which are about half these prices (and better spec too). If you have an OEM motor/gearbox/brake system and want to offload it, PM me please.
I wish...
I asked the question to see if it would be worth buying the R35 calipers themselves along with some Endless adaptors and some aftermarket discs. That would be a sweet stopping package for a 200kg lighter older series GTR (like mine).
Sorry, off topic.
So if something like this was to be wrecked you might be interested in some parts?
expensive.. weeeeee
Hey idiot, leave the stupid comments out of the thread - their not welcome here.
Judging by the posts it looks as though you're trying to get your post count up - typical. You're not contributing anything at all,
eg
Exhibit 1
Exhibit 2
Exhibit 3
Don't reply with shit that doesn't contribute!!
good luck with trying to get it over here mate....im sure if you did, youd basically be able to name your price on anything in it....plus the running gear would be an awesome retro fit into something like a 240/260z :P
yes we looked at buying it must be 6 months ago or more now. hopefully it's been well stored and is still in good condition. I thought it sold on ebay US?
the stuff is only worth what someone is willing to pay. but consider you could buy a wreck in japan for around $40K (or less) and import that as a parts car and I'd consider very carefully before you spend any decent time or money bringing it out here hoping to get $100K+ for all the bits.... JDM wreck would also be more desirable as it's RHD. also, that car was pretty heavily crashed, there have been a few wrecks around with less damage going for pretty fair money.
Oh my young friend.... if only you knew how difficult that task would be. You'd swear these 35's have a brain of their own, they know what you're doing to them, even without a battery in them! lol
I am considering getting the engine, transmission and brakes taken out and having them sent here... hmm, decisions...
This one looks nicer...
Edited by [200]
good luck with trying to get it over here mate....im sure if you did, youd basically be able to name your price on anything in it....plus the running gear would be an awesome retro fit into something like a 240/260z :)
someone do that please!!!
i couldn't see that black wreck fetching more than 25k
are you in the states? if not id get someone who has half a mechanical brain to check it out, and id assume with the new GTR a multimeter would come in handy to check all the electrics.
Being done ...
I might just bring the engine, transmission and brakes over and see how things go from there. It's all that's really useful on the black one.
Dude. Just put a price on it & see what happens. No-one here will put there hand up unless you put your balls on the wall & see what happens. Looks like a gamble to me. These things are that fast I dont think it will be long before we see a few local ones on the market like that (of course I hope not - but lets wait & see)
20 years to catch up? Hmmm. Didnt see Porsche at Bathurst 20 years ago. (But I was too busy drag racing Holdens back then to care anyway!!!)
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
