99 GTT Posted August 1, 2009 Share Posted August 1, 2009 Please feel free to add to this if i have left anything out. I have been looking through the forums and have noticed that alot of people are wanting to do this mod. I have put a small DIY together to try and help with the rewiring of the unit with a basic diagram. After removing the Xanavi screen, you will need to splice the some longer wires onto the triple cluster loom so to be able to enter the engine bay and connect the oil temp sensor and boost sensor as shown in the following attachment. (Note the boost and oil temp sensors cannot connect direct to ECU as these sensors are different) The second and easiest option is to use the factory loom Part Number: 24018-AA500. To do this you will need to remove the main cluster about 7 screws from memory. Now this should be as simple as plug and play to the factory loom. (Please note i have not verified this method as yet but as Nissan only make one Main Loom for the GTT the plug should be there) I hope the above helps someone and as last stated if something is wrong please correct me... I can also help with MFD conversion into R32, R33, R34 Skyline Turbo or non turbo. Easy to follow DIY to come.. Safe Driving Everyone.. 0o SKYLINE o0 Link to comment https://www.sau.com.au/forums/topic/281537-replacing-r34-gtt-pop-up-screen-with-triple-cluster/ Share on other sites More sharing options...
putraged Posted September 2, 2009 Share Posted September 2, 2009 do you have any idea how to put GTR MFD to R34 non-turbo? do i have to cut the dashboard? thanks Link to comment https://www.sau.com.au/forums/topic/281537-replacing-r34-gtt-pop-up-screen-with-triple-cluster/#findComment-4804829 Share on other sites More sharing options...
R34 -_- Posted September 3, 2009 Share Posted September 3, 2009 i wouldnt mind a pop up screen, the GT R34s look a little plain on the dash Link to comment https://www.sau.com.au/forums/topic/281537-replacing-r34-gtt-pop-up-screen-with-triple-cluster/#findComment-4805942 Share on other sites More sharing options...
Carbon 34 Posted September 4, 2009 Share Posted September 4, 2009 do you have any idea how to put GTR MFD to R34 non-turbo? do i have to cut the dashboard?thanks pretty sure the little panel unscrews just like the GTT , remove the air vents to see ? two phillips head screws are hidden behind it and slide it out towards you. the wiring is taped down on the harness . still trying to ponder why you would ditch the screen rather then use a Computer input to display the gauges in digital format but to each his own ? Link to comment https://www.sau.com.au/forums/topic/281537-replacing-r34-gtt-pop-up-screen-with-triple-cluster/#findComment-4807225 Share on other sites More sharing options...
putraged Posted September 4, 2009 Share Posted September 4, 2009 pretty sure the little panel unscrews just like the GTT , remove the air vents to see ? two phillips head screws are hidden behind it and slide it out towards you. the wiring is taped down on the harness .still trying to ponder why you would ditch the screen rather then use a Computer input to display the gauges in digital format but to each his own ? i got a deal for MFD, it cost me total 400. instead of ugly gauges i pillar A, i'll put 3-way sound system. but my R34 25gt didnt have any gauges in the middle dash. and there are no marks for me to open the dashboard and gain access to gauges mounting brackets. might as well cut the middle dash with dremel and create new brackets? Link to comment https://www.sau.com.au/forums/topic/281537-replacing-r34-gtt-pop-up-screen-with-triple-cluster/#findComment-4807732 Share on other sites More sharing options...
mcconnachie Posted September 11, 2012 Share Posted September 11, 2012 i got a deal for MFD, it cost me total 400. instead of ugly gauges i pillar A, i'll put 3-way sound system. but my R34 25gt didnt have any gauges in the middle dash. and there are no marks for me to open the dashboard and gain access to gauges mounting brackets. might as well cut the middle dash with dremel and create new brackets? i know this is old but what did you end up doing? my r34 GTT didn't come with any gauges in the middle nor a TV? i want to put the gauges is and im unsure how. Any ideas? Cheers Link to comment https://www.sau.com.au/forums/topic/281537-replacing-r34-gtt-pop-up-screen-with-triple-cluster/#findComment-6527781 Share on other sites More sharing options...
r32_rookie Posted September 14, 2012 Share Posted September 14, 2012 I'm curios if anyone makes the 3 gauge holder in carbon fibre? Link to comment https://www.sau.com.au/forums/topic/281537-replacing-r34-gtt-pop-up-screen-with-triple-cluster/#findComment-6533261 Share on other sites More sharing options...
