99 GTT Posted August 1, 2009 Share Posted August 1, 2009 Please feel free to add to this if you can help. The idea of the following DIY is to remove some of the confusion getting around this forum about the following install. Firstly get yourself a flat blade screwdriver and carefully remove the air con vents (may be a good idea to put a rag over end of screwdriver). Now remove the screws found in the front of the screen and remove from dash. Ok so now we are ready. The first and most simple way of doing this would be to obtain the Triple cluster Harness. Hopefully this has come with the Cluster but if not it can be obtained from Nissan Part Number: 24018-AA500. You will now need to remove the Speedo cluster, this is all of about 8 screws and it will come out. You may have to reach around and remove the 3 plugs from the cluster to remove it fully (good time to see if cluster has ever been removed) Now it should be as simple as plug and play the triple cluster harness into main loom (see attached diagram) (Please not the above method i have not tried but as Nissan only make one Main Loom the plug should be there. If some one can verify when they try that would be great) The second way this can be undertaken would be to slice the wires onto the correct sensors that are located in the engine bay. (Please note that the pinouts on the ecu 47 and 60 can not be used for this) Please see the following attachment for digram and wiring layout. Well i hope that this helps someone on here and if i can help any further please ask. R34 GTR MFD easy to follow DIY help also avalable for R32 R33 R34 Skylines turbo and non-turbo. Safe Driving To All... 0o SKYLINE o0 Link to comment https://www.sau.com.au/forums/topic/281541-replacing-r34-pop-up-screen-with-triple-cluster/ Share on other sites More sharing options...
99 GTT Posted August 4, 2009 Author Share Posted August 4, 2009 OPPs Double post in DIY ... Sorry people.. Link to comment https://www.sau.com.au/forums/topic/281541-replacing-r34-pop-up-screen-with-triple-cluster/#findComment-4749026 Share on other sites More sharing options...
shinyurikai Posted September 4, 2011 Share Posted September 4, 2011 haha i had that on my old R34 four door i turn it into a tomtom navi man with defi guages as the top. Link to comment https://www.sau.com.au/forums/topic/281541-replacing-r34-pop-up-screen-with-triple-cluster/#findComment-5999771 Share on other sites More sharing options...
iwanta34gtr Posted September 4, 2011 Share Posted September 4, 2011 I have a standard cluster if any1 wants 1. PM me. Nice diy. Link to comment https://www.sau.com.au/forums/topic/281541-replacing-r34-pop-up-screen-with-triple-cluster/#findComment-6000764 Share on other sites More sharing options...
madman_rocks Posted December 16, 2011 Share Posted December 16, 2011 haha i had that on my old R34 four door i turn it into a tomtom navi man with defi guages as the top. Hey I have one with the tv thing Wat size and type and how did u get the tomtom in Link to comment https://www.sau.com.au/forums/topic/281541-replacing-r34-pop-up-screen-with-triple-cluster/#findComment-6155161 Share on other sites More sharing options...
