Please feel free to add to this if you can help. I tried to post this in DIY but no luck so its here. :)
The idea of the following DIY is to remove some of the confusion getting around this forum about the following install.
Firstly get yourself a flat blade screwdriver and carefully remove the air con vents (may be a good idea to put a rag over end of screwdriver).
Now remove the screws found in the front of the screen and remove from dash.
Ok so now we are ready.
The first and most simple way of doing this would be to obtain the Triple cluster Harness. Hopefully this has come with the Cluster but if not it can be obtained from Nissan Part Number: 24018-AA500.
You will now need to remove the Speedo cluster, this is all of about 8 screws and it will come out. You may have to reach around and remove the 3 plugs from the cluster to remove it fully (good time to see if cluster has ever been removed before e.g. damage to plugs due to them being hard to remove)
Now it should be as simple as plug and play the triple cluster harness into main loom (see attached diagram)
(Please not the above method i have not tried but as Nissan only make one Main Loom the plug should be there. If some one can verify when they try that would be great)
The second way this can be undertaken would be to slice the wires onto the correct sensors that are located in the engine bay. (Please note that the pinouts on the ecu 47 and 60 can not be used for this)
Please see the following attachment for digram and wiring layout.
Well i hope that this helps someone on here and if i can help any further please ask.
R34 GTR MFD easy to follow DIY help also avalable for R32 R33 R34 Skylines turbo and non-turbo.
Safe Driving To All... ;) 0o SKYLINE o0 :(
Edited by 99 GTT
https://www.sau.com.au/forums/topic/281542-r34-pop-up-screen-to-triple-cluster/
  • 5 months later...
Heya
I performed this conversion on my friend's R34 GT today. Had the fancy pop-up screen thing, which didn't work. (Random jap error message, open/closed at random, etc).
We got the gauges with the loom included, confirmed Part No 24018-AA500 as per tag attached to the loom.
I was not able to find any suitable connector to plug into. Keep in mind the gauge loom is going to follow a particular path, it is of a certain length, the corresponding plug would have to be in reach, but none was found. It also has two mounting plugs the same as that found on the loom for the screen loom, so I presume they mount to the same plastics on the dash (behind the cluster).
Given a car cannot have BOTH the triple gauges and the screen - only one or the other - I believe the wiring of each car is going to be different. There are other components too, such as the buttons where the climate controls are usually, as well as the computers in the boot. So when the car was made with that option specified, I'd put my money to say it was fitted with an appropriate loom from the factory. Vice versa, at the same time I can almost guarantee my GT-T which has the guages stock will not have the TV connectors/wiring in place.
To install the gauges, I cut the plug from the end of the loom, and spliced the 2 x Earth, Ignition 12v and Illumination into the wiring for the main cluster. I opted not to attach to the TV Loom, incase removing other components ceased power, illum. etc to be fed to those plugs. Not to mention it was much more difficult to decipher. For the Oil and Boost sensor wires, I've attached a few meters of wire to each to run to the engine bay to fit sensors later on. Alternatively, yeah, one could fit aftermarket gauges.
Edited by Rake
  • 11 months later...
that 3 guage cluster one is just wat i needed to install some aftermarket guages in there thanks bud :cheers:
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
