Lets say I get the top feed fuel rail, a set of 6x 444 GTR top feed and the transistor box to make them work, Will they fit in my fuel rail o-rings ??
They will be managed by a PFC.. So im guessing its not that complicated if they do it on the RB20, Only diff is the Rb25 has side-feed injectors but the fuel rail would correct that probleme ? I know stock fuel pressure for my RB25 is about 36-38PSI , would I need to make ajustements for the GTR injectors ?? What is the fuel pressure for a stock GTR ??
THanks for any info !
https://www.sau.com.au/forums/topic/281544-rb25-w-gtr-top-feed-injectors/
rail mouts is not a problem but now for the injector O-ring ... Are the rb20 and rb26 ones to small to fit in the rb25 socket or is it the rb25 socket that is to big to take the 444'S Tips ?
Will the rb20-rb26 O-rings fit in the Rb25 Plenum ?
Thanks again for the info !
Have you tried a search, this has been done heaps of times. Short answer, you buy alloy conversion collars, try the For Sale section and use an RB26 or RB20 fuel rail, done.
If you can't find them in the For Sale section, Hi Octane sell some expensive Japanese brand conversion collars, GReddy if I remember rightly.
Cheers
Gary
Thanks Sk
=D
i did this two ways, first was with a rb26 stock rail, running a rb26 pfc on my rb25 and it was ok til a pinhole in rail made it a flamethrower, i used custom brackets to hold the rail to the intake ( i have a custom intake with rb25 lower halve) than i used a ebay fuel rail for use with stock rb26 inj, we modified the mounting tab and drilled new holes and it now works wonderful
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
