Easiest way to power a system like that:
Quality: http://www.shoppingsecure.com.au/index.php...mp;productId=12
Value: http://www.shoppingsecure.com.au/index.php...mp;productId=38
Good pair of Splits for the front:
Italian: http://www.shoppingsecure.com.au/index.php...amp;productId=5
British: http://www.shoppingsecure.com.au/index.php...mp;productId=52
Good installers? Are you closer to Sydney or Newcastle?
Newcastle: http://www.shoppingsecure.com.au/index.php...mp;productId=43
Syndey: I will need to get back to you if its closer
Everyone was throwing in their opinions I thought I might as well throw in mine! :P
i wouldnt use jaycar gear as an anchor for a boat, let alone put it in a car. you're playing with yourself if you think otherwise, it's not better than option audio shit.
Hey its a decent option, it did win 1st place over lots of big hitters ?
and yes I do know a tiny bit about pro car audio, 16 + years worth of it now.
not knocking Option Audio, its a great product as well.
doesnt matter what brand if its installed like crap is the point Im making
thanks guys for all the help. ;)
The only thing im struggling with is going to be the installation of the whole thing :) I forgot about all the wiring rules like Certain cables run down one side and other cables the other side, stuff like that :stupid:
All brands have their place. If I had the choice of using a high quality Italian amplifier or one of the Option Audio or Jaycar amplifers then I would choose the Italian one. I would get a lot more quality but my wallet would also be substantially lighter.
As for the wiring rules, keep your RCA cables away from your power cables, simple.
i got my system installed by Car Audio Excellence in Penrith in my old car, and they always play it safe with their installs and dont tune the system to its true potential. When i got the car back i thought "is this it?" and then got home and started playing with the amp settings. It sounded so much cleaner and deeper when i finished. It did put extra strain on the Amp but it was a shitty boss amp so i didnt really care.
Point: Install/Tune makes a huge difference
Just realised that your in the opposite direction from Sydney than Newcastle! I can't edit my post..
A good quality 4 guage power kit is what I would use. I can't recommend any kits that I know off by heart.
4 ga wire can handle the power below in red. it should be fine your install, any 2 amp wiring kit, with 4 gauge in it should be fine, you do get what you pay for in connections kits. but dont overlook ebay , most of that is more then good enough on a budget .
otherwise, street wires, or any name brand from the dealers. I used US Audio for the cheap installs, works fine saves some cash
4 GA max load is 135amps, 60amps continuous load safe
I thought he wanted a budget system, and not going for crazy install type.
Thats why i recommended the Response series, but if you wanna' start being an idiot then yeah, lets go Digital Designs over your Option audio ..
Dont start ranting here if you got nothin' better to do Mr Clinton..
As for wiring, I havent tried the whole " ebay wiring kit " venture so i cant comment.. Spend a lil' bit of money and get something reliable, coz' you need to understand your running a fair amount of power through these wires, and if something was to go wrong .. well you get the picture.
So i would recommend nothing smaller than 4Guage IMHO.
http://www.ryda.com.au/Aerpro-AP962-1000W-...4GA-p/ap962.htm
or
http://www.ryda.com.au/Stinger-SWK4-Amplif...-4GA-p/swk4.htm
I'd go Aerpro for your simple setup.
MRXTCZ
or
MRXTCZ
FYI - most wiring for the ebay kits is re labeled or unbranded kits from china,asian for big companies, like aeropro, stinger, etc
the installers/biz owners like myself who visit the dealers at the CES in vegas can attest to that. doesnt make it rubbish.
the thing to watch for is the RCA wires, some are pure crap, used stinger brand for a long time with only a few failures over the years on RCA
power wires dont fail unless , too much current is pulled thru them ,burn jackets from being to close to heat sources like exhaust, or sharp objects cutting into the sides. just make sure the jacket is flame proof, flexible, do not use solid core wire, never , ever!!!! in a car
and fuse/ curcuit breaker at the battery is setup to blow before the amps load, I would use a breaker, lots cheaper in the long run and quicker to reset
if the amps max current draw =110 amps
use a 80/100 amp fuse/ breaker at the battery to" PROTECT THE CAR" , not the amps, the amps should be fused on the side of them or very close by to amps if the fuse isnt on the side of curcuit board already.
you will never hit the fuse breaker point in 99.99% of the situations playing music, but a short curcuit to ground will hit it in a milli-sec. which is enough to start the car on fire from arc welding thru 4ga cable? so make it as close as humanly possible to the battery, and use damn good grounds, battery terminals too ???
I need a amp kit and a power kit yeh?
need both or just amp kit will do? lol
and you would recommend stinger brand? or .... ?
Edited by Black R34 GT-T
  • 3 weeks later...
The only thing im struggling with is going to be the installation of the whole thing :laugh: I forgot about all the wiring rules like Certain cables run down one side and other cables the other side, stuff like that :D
hey mate, im a fitter if your still looking for an installer, im located near chatswood just contact me on 0414 69 00 83 if u want a quote
cheers, paul
