Hey All,
I have all these parts that I no longer require and have decided to sell them off! I'm located in Adelaide but am willing to post
interstate at buyers expense. All the parts have come from a 33 vspec GTR and 32GTR and are all in great working order and
not damaged in any way. The parts themselves are used but as above in great working order. If you are interested in any of
the parts feel free to send me a PM.
R33 centre grille -$100 (off gts-t)
R33 N1 front bar -$200 (off gts-t)
Harmonic balancer (32GTR) -$50
R33 alternator -$80
AAC valve and air chamber (X2) -$100
RB26 stock fuel rail + reg (X2) -$30 ea
Intake manifold assay (injector plate) -$250
RB26 throttle bodies + linkages -$250
RB26 440 injectors X6 (R33) -$250
4WD sump,baffles and gears -$300
Rods and pistons (2 pistons have ring land failure) -$100
R33 Vspec turbos 024U dumps,heat shields, exhaust manifolds and O2 sensors -$500 pair
R32 05U turbos with as above -$300 pair
Front cover baking plate -$50
Idle control valve -$80
TPS (throttle position sensor) -$100
Autometer oil pressure guage (psi) -$30
Splitfire boost guage (psi) -$20
Exhaust manifold heat shields + dump heat shields -$20 the lot
Y twin connecting pipe -$30
Air flow meters (X2) red label - $200 the pair
th_08022009265.jpgth_08022009270.jpgth_08022009271.jpgth_08022009272.jpgth_08022009275.jpgth_08022009276.jpgth_08022009278.jpgth_08022009282.jpgth_07122009210.jpgth_08022009283.jpgth_06282009154.jpgth_08022009284.jpgth_06282009152.jpgth_08022009286.jpgth_06282009172.jpgth_08022009287.jpgth_06282009173.jpgth_08022009288.jpgth_05302009098.jpgth_08022009289.jpgth_05302009105.jpgth_rb26parts033.jpgth_rb26parts028.jpgCheers HULI
https://www.sau.com.au/forums/topic/281569-rb26-engine-parts-sale/
hey mate interested in 33 n1 front bar off gtst and r32 turbos what do you think fraight to central coast nsw will be. pm me of contact me on 0411672105
Hey All,
R33 alternator -$80
AAC valve and air chamber (X2) -$100 *****(1 REMAINING)****
TPS (throttle position sensor) -$100 ****SOLD****
Hey All,
R33 alternator -$80
AAC valve and air chamber (X2) -$100 ****1 SOLD/1 REMAINING****
Front cover baking plate -$50 ****SOLD****
Exhaust manifolds, heat shields + dump heat shields -$20 the lot ****EXHAUST MANIFOLDS SOLD****HEAT SHIELDS LEFT
IF YOU WANT TO MAKE A REASONABLE OFFER ON THIS STUFF THEN DO SO, BUT THOSE WHO ARE TIME WASTING WONT BE REPLIED TO AT ALL!!!
CHEERS HULI
    • I'm not 100% how the BMW racers do it, but I know from other brands like Merc, moving, and changing the coolers is one of the things. Like getting a transcooler out from infront of the radiator to out near a wheel arch. So some of the stuff you've got crammed in the middle front, spread it out and open up where you can in the bar to get more air in to the sides.
    • Small update for the day... Turns out the intercooler and engine coolant hose kits are anything but complete....I probably should have counted better but it only really covers about half the coolant hoses in the car, it really just covers the visible stuff and pretends everything else doesn't exist (turbo water feed and returns and also heat exchanger lines through the 2 pumps and cooler) .In any case, I'm happier to have half reliable hoses than none, but a bit of a disappointment. Anyway...finger click (and 5 hours).....hoses in place, lots of spring clamps replaced with screw clamps, and engine coolant is on the pressure tester for the night.   Incidentally, upsized header tank is an Inifiniti factory option....not sure I'll ever do prod car racing in this but at least it is legal.
    • Just weld it onto the hot pipe. If you want it right after the turbo, put it right after the turbo. Or rip the comp cover off and drill and tap a hole into it.
    • hahaha glad I can rely on you two to go on a spiral at the drop of a problem! Some quick answers....the ducting is excellent top bottom and sides....everything that gets in goes through the coolers (noting the oil cooler redirects it out again, fair call if it is cooling 120o+) and the heat exchanger for the intercooler also has some scoops to pick up more than it's fair share too. I can't see going down the water spray track....no bueno for formal racing and a big risk for long rally days if you run out (plus I'm not clear if it is allowed there either yet).   Frankly, it must be possible to reliably put 400kw through a standard front end, the BMWs do it so I just need to work it out....I'm starting with reducing blockages in the way and adding some coolant capacity with a bigger header tank, flushing rad and making sure it was filled/bled properly (I didn't do the last coolant change); also taken measurements incase next step is a bigger/higher capacity custom radiator
    • wow, a completely stock GTR! I've got to admit, I have no idea from what you are describing....do you have  any idea where the "thump" comes from, and are you certain it is the HICAS light not something else like the cat overheat light?
