  • Replies 71
A lot of this talk is merely a relative experience and response in the user. Unless you actually measure the Gs using a VBOX or similar this thread is just full of subjective talk. The Gs at any point are of course simply a reflection of power or power to weight.
GTR + 4000RPM (or more) launch = Obliterate anything off the line.
Really?
Busa-
1/4 Mile ET: 8.442 1/4 Mile MPH: 166.980 1/8 Mile ET: 5.521 1/8 Mile MPH: 136.870 0-60 Foot ET: 1.430
Well almost anything.... :devil:
The list is definate and goes as such:
Bugatti Veyron
Gold/Yellow dragon (dependant on how often you polish your dragon)
VteK Civik (yo)
Super charged R34 with 500awkw
Green Dragon
The next Noob's GTsT with a 3in Zorst and a "special Jap chip"
Red Dragon
R35 GTR
Closely followed by the car with the highest power/weight ratio to the one with the lowest...
Bugatti Veyron
VteK Civik (yo)
Green Dragon
Red Dragon
R35 GTR
GOLD
Yes just buy yourself a veyron and earn the admiration of all but the "nissan is the greatest" types on this forum. Wanna spend $20,000 instead of $2,000,000? Get a road bike. And life insurance. Or just add a big wing and some stickers to pretty much anything and go to maccas. The respect you command will be very similar.
How many were sold in Australia? I don't think it's completely out of the question, though unlikely I'll admit. Some members do appear to have piles of disposable income, and even enough taste to own things beyond Nissans, so the question stands.
Bugatti Veyron
VteK Civik (yo)
Green Dragon
Red Dragon
R35 GTR
A seriously comprehensive list. Close the thread now. :)
Close...Modified R32 GT-R on a prepped track, limiter launch.
Really?
Busa-
Well almost anything.... :)
:P
LOL!
Just from my own experience as my R32 GTR came with a HKS twin plate and I was still getting use the friction point and I revved to about 4000 RPM (So I would not stall it) and as so as it engaged I was pushed back into my seat LOL!
Yes jase-r34 I am sure there are other cars as well, I am just speaking from experience :(
Really?
Busa-
Well almost anything.... :P
Busa is the stuff but with that 60 footer time you'd be behind the GT-R...for little while longer anyway
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
