as far as the rim width goes you will get away with it if you run the same sized tired on front and backs to keep the ATTESA happy
just to clarify, he's get away with the same sized tire in this instance as there is only half an inch difference in rim width but the rule of thumb for attessa is same overall rolling diameter
https://www.sau.com.au/forums/topic/281589-wheel-help/#findComment-4745157
should be apples, there are stacks of tyre size and rolling diameter calculators on the net that you can use - check to see that the rolling diameter front to rear is the same and you won't have the attessa kicking up a fuss.
it's generally just easier to run same wheel and tyre specs front to rear, which is why most people do it, but there is nothing saying you have to
https://www.sau.com.au/forums/topic/281589-wheel-help/#findComment-4745173
225 and 235, different sizes so different rolling heights. i wouldn't want any more than about 3mm difference in rolling height front to back on my car and the difference between a 225 and 235 will be bigger than that
D.
https://www.sau.com.au/forums/topic/281589-wheel-help/#findComment-4745690
dave, don't forget his rear wheels are half inch wider. i'd think it would be ok (without checking, which i have recommended he does himself) but i'll admit you'll know more about tyres than i ever will :P
it also gets tricky if they are different tyre brands as there can be quite a variation in the way tyres bead up even though they say they are the same sizes
https://www.sau.com.au/forums/topic/281589-wheel-help/#findComment-4745697
been told by a mech, who had someone come in with different size rubbers.
he said at 80-100ks it would start to vibrate and almose feel like the back wheels are trying to overtake the front wheels.
so not a wise thing to do with the AWD system, it was on a series one stagea too.
https://www.sau.com.au/forums/topic/281589-wheel-help/#findComment-4745865
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
