COPYME, I agree completely. Are you sure this guy is on the level? I would have thought 99% of people would have raised hell if a copper took to their car with a stanley knife.
paullys 32, if you click on the flag that asks if you want to be remebered (when you first log on to the site) the computer will load up cookies which identify you when you revisit - therefore if someone else uses your internet login, they will login as you. Do you have a younger brother?
If you dont want this to happen again, you will need to go into settings and delete all your cookies and then next time you visit you will be need to login, uncheck the 'remember me' check box (or whatever it is called) and login. The cookies then wont be downloaded.
Pretty sure he gave little descriptions bout what happened, and he wouldn't have if he was having a tug.
if anyone, including a police force member touched my window tint, id be mailing their balls to them via australia post.
I believe a cop touching your window tint, especiailly with a stanley knife, is property damage, what would have happen if he had made a nice big scratch into the glass of the window...
My lawyers would have a field day with it! People need to know that just because they wear a badge does not make them god!
I know someone that can sympathise with Dean re: his Regency problems now.
My friend has a GTI-R which has now been defected three times. The car is pretty much stock except for it being too low.
The first two times he put the car back to standard height and went through Regency without a problem. Last week he went through Regency for the third time and they wouldn't pass his car saying that he had a bent chassis rail.
How could this damage go unnoticed the first two times the car went through Regency?
Who have they got working down there??!!
Thanks for the sympathy :D
It seems that this sort of behaviour is happening to alot of people. This sort of treatment is the reason i barely drive my car now. Why bother paying so much insurance for a car that hardly ever gets driven. It never goes near the city now. Only work and Uni. If things get worse, i will sell it. Its just too much of a headache.
It seems pretty obvious to me re the 'bent chassis rail'.... Regency staff didn't "miss" the bent chassis rail the first 2 times, rather they chose to find a tiny defect with it on the GTi-R's third trip through. Why did they do this? Because they decided the owner hadn't learnt his lesson the first two times. And before anyone asks... no, I don't agree with their (Regency)methods, but I can see why they're doing it.
I do totally agree, I think if you're silly enough to get your car defected three times then they're bound to pick on you.
It just seems silly to me that such an obvious defect was not picked up earlier. My point is just the inconsistencies in the way everything works. You get different people looking at the cars and different defects being pointed out each time.
They should all be looking for the same things and not overlooking obvious things such as a bent chassis rails.. Dean can vouch for this too, they didn't pick it up the first time, but second time around, there was the defect.
i read that thing about the gt4 celica and i read it like 5 times over. I dont know about u but to me it seems to me that jaustech and who ever else originally complianced or "plate swapped" the original car are dodgey. And i think what regency are asking to be done now is what should have been done years ago when it was complainced. I keep reading it and evey time i do it seems that there is something dody going on. I would like to see the car to see if the vin number on the GT4 chassis matches the VIN on the FWD plates because if they do **** i dont know what they have done.
ALso on that gtir where is the bent chassis real, if it is near the mounting points of the front sway bar that is a common location for the rail to bend and the crack, I had to have both my rails in mine plated and welded. U never know that this could have just developed as this does happen over time. It does it because the N14 chassis is just too weak for the heavy front end of the gtir motor.
Shannon and Matt, are you guys saying if you got your car defected you would return it to stock and leave it completely stock?
Anything on your car that isnt OEM may give rise to doubt and off to regency you go. Then again, I have been told stories of people being defected for stock BOVs - as, to quote the traffic cop I spoke to at Holden Hill - 'all BOVs are illegal, if your car has one, it will be defected'
The last time Dean got defected, as he points out, he was just going to the movies minding his own business, how does this make him 'silly enough to be defected'? His car has alot less mods than so many cars on the streets.
With the law the way it is, no one is immune.
    • Let me assume that the concern over a manual ECU is that the NeoDET that you have was an auto and has an auto ECU. That ECU will not be a problem, but you WILL have to Nistune it. And you would have to Nistune it even if you had a manual ECU, because the turbo ECUs will shit the bed if they do not have all the things that they were told they have to have, to be happy. The big one being the TCS CU, which you won't have in your car. Anyway, with an auto ECU (which I have running my originally auto NeoDET in an R32) Nistune allows you to put in a Stagea image which doesn't panic about the absent TCS, and allows you to override a whle bunch of other annoyances that would otherwise see the check engine light on 100% of the time. Also, you can't wind up the power very far on the stock NeoDET ECUs without Nistune, because the boost sensor gets in the way. Nistune allows you to push that problem much further up the dial. Do you even have the boost sensor with the engine? Without it, you are SOL and will need an aftermarket ECU (or to find a sensor somewhere, god knows where). I can't tell you what the wiring loom differences are in a 34. But what Duncan said above needs to be considered. When you say "loom", does that include the transmission loom? Because you will need to swap out the auto tranny loom for the equivalent manual loom, and get rid of the neutral/park start interlock (basically hot wire it).
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
