I'm still of the firm belief that ISO acreditation would solve most issues here due to the necessity of a paper trail and accountability. You cant break protocol with personal and random opinion with this in place, and there will exist a resolution procedure for unhappy customers, which will by necessity require documentation on their part. The fact that SEVS makes this mandatory, only to have the 'approval' body escape without it is simply ludicrous, and reaks of inconsistancy. Also are there any degreed mechanical engineers present? Without such no one is suitably qualified to make a judgement call on mechanical modifications. I thankfully have never had to go through this trauma but fully sympathise with those less fortunate. I think it would be easier to succesfully argue this implementation, and everything we are looking for would be necessarily covered and under the 'guise' of modern practice, which should make any politician happy. Does anyone else have any opinion on this?
I do agree that ISO certification, or at least a visable form of quality assurance would go part of the way, but I dont believe it would go far enough.
currently Regency hides behind its interpretation of ADRs and provides exemption on occasion, apparently at whim. Certain things though they flatly refuse to look at.
The problem with this is that there is no scope within ADRs for modification to vehicles - they can be interpreted both for and against the enthusiast - most states lean on the side of the car owner, as long as the mod is safe. For example in WA it is ok to fit a blow off valve, in Qld you can fit an ECU or upgraded turbo, as long as you can pass a dyno emissions test Further, where mods fall completely outside of the original design of the vehicle, and if an appropriately skilled engineer certifies a car can be driven on the road safely, approval is granted for the car to be street registered.
All fair, with an emphasis on public safety, not bloodymindedly enforcing rules out of the context that they were originally intended.
what i seriously dont get is this. They will let u fit a bigger newer engine to ur car, ie a big v8 in any small car, yet they wont let u put a turbo on it, as according to regency, by doing this u are basically becoming your own car manufacturer and have no emmission results as such.
But do they think about how differently the car will handle with this hunk of iron in the front of it instead of the old pos small engine. Basically all frontal crash testing would become void, car handling charateristics change, chassis may not be up to the task, etc etc etc.
The fact is its ludicrous that u can change the engine but not change the turbo...
If you replace the engine with one more than 20% (from memory) larger than the largest fitted, you have to have an engineers report and do lane change stability and braking tests.
The big thing is emissions, if you havent changed the charactheristics of the engine you fit, ie its still OEM in all regards, you only need to provide a 2 gas emissions test, which can be done at most dyno shops.
If you change anything on the engine though, you need to prove it still complies with the ADR, which means a minimum of an !M240 test, which is what Regency said they need to prove compliance. There are no IM240 test facilities in SA, only the mitsi ADR37 test facility, which will cost $3.5K.
Interesting to note:
DOTARS 2million dollar study into vechicle emissions, recommends a steady state 60kph test be adopted for proving vehicles still conform to emissions stadards, which is cheap.
Also Stephen Bell has an RG240 test, which is accurate to within 10% of the IM240 test, and costs $375, and in Tim Ireland's own words, 'if it passes the RG240, it should pass the IM240', went on to say that they wouldnt accept it though.
Another thing that shows the extent of the beaurocracy, if you modify a pre 1972 car, no emissions test is required, as there are no applicable ADRs. Tim Ireland recommended that if I want to modify a car, to modify a pre 1972 car for this reason. Makes sense doesnt it, go and modify an old ford or holden, slap twin turbos on a 350 or 351 and its quite road legal - great service they are providing, making sure cars are safe on the roads eh?
In effect, the enforcement and interpretation of current regulations is encouraging people to modify OLD cars, and there is no way they would be safer on the road than a later model car - as I said before, beaurocracy out of control.
  • 1 month later...
Steve, more info for u: Did u see last week in the Advertiser, there was an article about regency. Basically it was about written off cars getting re-birthed, but what is concentrated on was the inconsistencies and lack of structure that regency has. Regency now say they are going to review all there proceedures in regards to this. Maybe this article would be helpful to u and us.... If u dont know about the article, ill see if i can find it, but i know it was definately last week somtime in the advertiser.
The last SAU hills cruise I went on (not last weekend, the one before) would've been right up your alley Steve. 8 or so cars, no idiot drivers, a spirited run through some nice twisty hills roads, with nil unwanted attention. Perfect!
Wow just read all 8 pages (took a while)!!!
Well done for taking a stand and I hope that what you do can make a difference cauz regency is an absolute joke!
I'm probably going to be importing sometime in the near future and I really hope I won't have to put up with some of the bullshit that you guys have gone through. Keep up the good work!!! :)
I agree totally Steve. A mate of mine just bought a Evo 3 from Victoria, (technically its a GSR modified into an Evo 3 as you cannot import Evo 3's in Australia.) However, all the modifications have been approved and the car came accompanied with an engineer's certificate for ALL modifications, and was cleared and registerd in Victoria, complies with all ADR's and then he gets it here and Regency says, sorry we don't care about your engineer's certificate or the fact that the car's already been registered in another state, we want a full inspection and we'll tell you when we feel like doing it! The poor bloke tried to explain that he was gonna be in breach of contract if the car isn't registered with SA plates under his name within 2 weeks and they didn't even give a f**k!! I mean the car was Aus. Delivered to begin with and has already been cleared!!
I keep my car under Vic rego because its harder to defect, most cops including traffic in SA have no idea about how different the defect rules are in VIC and can't be bothered pulling out the handbook to look them up.
Keeping things such as BOVs on the pipe under the wheel arch help alot to avoid defects. One sentence that will help you immeasurably is "The engines out put is no higher than factory!" But even if i get a defect the VICROADS system means that i go see a VICROADS certified representative just over the border and they will remove the defect.
Customer service over there is amazing with VICROADS. You call them and tell them what you want to do, but instead of saying you can't do that or just a plain NO. I got "well if you want to do that the best way to do it and avoid problems is....." The only problem is that when you register the car overthere you need to deminstate that you have an address is VIC , but to do this you don't even need a bill with your name on it, just a relative.
hey guys got pulled in to a defect station at mt pleasent just out of birdwood
got done for tinted windows ( whitch he tested with the back of his hand ) and gauges (which are below the dash line , aswell i have to go through regency because of the tint , the question is , is there neway around regency and geting it off at a cop shop instead or am i screwed ?
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 馃槓
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
