When im driving around my car is fine but if i switch on my headlights fully about 5 seconds later my car will just cut out, the rpm would drop to 0 and it will just stall or lose power and suddenly kick up again by itself. I've checked the voltage of the alternator and battery all is fine. Anyone have any clue to what's causing this?
https://www.sau.com.au/forums/topic/281626-headlights-electrical-problem/
With R32's at least, the headlight power runs all the way to the headlight switch on the dash. Usually when the headlight switch plays up, one side's headlight is powerless while the other is powered. It's not a cheap part either to replace, and it might not be the source of the problem just my 2c.
  • 9 months later...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
