  • Replies 187
Posted Images
Zennon, thats an awesome picture! Bit dark though, but thats just my opinion.
Yeah think you're right actually - it looked fine at home but then when I saw it on my work pc is was like :)
(then realised it was because I had played with my gamma and brightness at home so i can see the bloody counter strike campers :) )
OT
what do you think of the innov8? im tossing up that or an ultra touch.. my nokia N85 is rubbish never again!
the innov8 was barely sold here. Mine was bought overseas from ebay. Very hard to find one here and hence running overseas firmware (couldnt find australian firmaware) It doesnt affect the functionality of the phone but.
Depends what you are after on a phone.
The innov8 has wifi and runs on symbian OS (same operating system as the new gen nokia's, so there are many applications you can run. After you crack the phone there are a lot of apps to download. Ive got about 3 different GPS programs and 2 different office suite apps) also has 8gb or 16gb internal memory.
Also the middle button on the innov8 is infra-red sensor, so you slide your thumb over it to move the cursor when browsing websites etc. Think of it as a mini touch pad on laptops. Although its much more sensitive as its a small pad.
Quickly reading about the ultra touch, they are touch screen but dont have wifi or big internal memory. however they are very small phone.
sweet ill go grab a 16gb one then, my only prob with internal mem phones is if you drop it in water you cant easily remove the mem card to download your data, just means more frequent backuping....
The i8510 does have a memory card slot, so you can get a 8gb internal and then buy a 8gb card if you want.
first attempt at some panning shots.. lots of practice needed... and a decent lens for it, was using the 50mm for these ones. I think.. might have been the stock lens too..
what noticable difference does the lens make when panning?
yeah I know you can do it with any lens, but with the 50mm it was hard to get the whole car in focus, it usually focused on the rear or the door or the front but not the whole thing
don't use it wide open then?
he was using f22.
i dont think you did to bad considering they were taken at 1/40th of a second. maybe start at 100th and work your way down from there. although im no pro so take that with a grain of salt.
Edited by Jay019
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
