  • Replies 187
Posted Images
My first Wedding gig:
Well i have done engagement parties for friends before, but this was my 1st experience doing a whole wedding including the pre-wedding photoshoots (done few months ago).
I was the 2nd shooter for both the pre-wedding photoshoot and on the actual wedding day.
Would like to say a big thank you to jackie for letting me be part of it.
Well I hope my pictures have captured not only the love between the couple but also captured a moment that will never be forgotten.
I have taken well over 10gbs of pictures, but i will only post up a few.. I still got 5 more gbs or pics to go thru!! Sigh.. anyone wanna help?? lol
Oh and i concentrated more on the bridal party and guests.. So you will see more pics of the bridal party.
1- My fav from the pre-wedding photoshoot:
Wedding pics now:
2 - Relatives and friends throwing rice at the couple (this is an very old tradition)
3 - Bridal Party:
4 - Bridal Party:
5 - I like this pic for some reason
6 - The bridal party having a nice chat!!
7 - The boys really wanted to do this pose for some reason:
8 - A weird edit from me: Sorta like it :)
Edited by siddr20
ps sorry about my brief response - have more time now
in short
its when you take a couple of versions of the same picture (at different exposures) and stack them together
most SLRs have a built in function called bracketing which will allow you take these photos (eg one normal, one dark and one light)
but you can also do it using one picture - by creating the light and dark ones using the normal picture
this might be a bit overdone and not look real but shows you what i mean:
ahh thats awesome man, thanks for that.....
im just using my tough panasonic lumix to take pics, nothing amazing... so all the effects will have to be done afterwards..
but a huge improvement i might have a play right now :down:
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
