Hey up fellas and ladies, I am selling:
FULL ENGINE SERVICE MANUAL for the
R32 GTR
and
R33 (RB20E, RB25DE, RB25DET & RB26DETT)
and now
R34 SERIES!!
These are organized into A4 ring binders. I realize that these are available on CD but to print these off (which is much more practical when you need to look at the manual under the bonnet of your car) costs a alot of money and ink as the R32 SERVICE MANUAL is 804 pages long! (About $160 to photocopy)
I however am able to produce these at less than retail/domestic prices,
to that end it is well worth the money:
R32 ENGINE SERVICE MANUAL --- $20.00p
R33 ENGINE SERVICE MANUAL --- $20.00p
R34 ENGINE SERVICE MANUAL --- $20.00p
Please enquire about P+P costs as these are being posted from UK and P+P is dependant on which manual you require)
PAYMENT BY PAYPAL IS PREFERABLE
(please PM me for payment details and your delivery address)
Please see pictures below, these are not photos of the full contents but part of it to show they are indeed the full manuals
I am a member of www.skylineowners.com and have sold many of these with NO NEGATIVE FEEDBACK :P
hey man can you get full work shop manuals for the r32 gtr, as in not just the motor
the manual is for the GTR COMPLETE butty, not just engine. They are what the factory fitters use, includes all specification tables, full diagrams, gow-to's etc. very comprehensive, I use a copy of the R33 manual myself and its fine,.
Have you got any for the old rb20det redtop eccs?
Dave
only got whats listed at the top of the thread people :-)
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
