I don’t really want to sell the car (hence the price :P) but if someone is serious then I guess I’d let it go. Even with the current price of R33s you couldn’t build this car for the asking price (thats based on a purchase price of $7000!)
1993 Nissan R33 Skyline GTS25t 2 dr
Black
5 Speed manual
185000 kms
Exterior:
Type M body kit – series 2 rear wing
Nismo clear side winkers
Rims:
F-18x8.5 R-18x9.5 Starcorp Impuls – White
Suspension/Brakes:
Sydneykid Whiteline/Bilstein combo – fixed Whiteline swaybars front and rear
Adjustable Rear camber arms.
HICAS lock bar
Rear cradle “pineapples”
Adjustable front castor arms
Strut braces front and rear
RDA slotted rotors front w/ Ferodo DS2500 pads, standard rear rotors w/ Lucas pads
Brake master cylinder stopper
Interior/ICE:
Series 2 steering wheel
R33 GTR seats – driver and passenger
Series 2 rear seats
Nismo GT shift knob
Pioneer CD/MP3 HU, 6” Pioneers speakers front and rear, 12” Fusion sub w/ Jaycar Response amp running sub and rear speakers
Engine/Exhaust/Driveline:
RB25/30 Built by Elite Racing Developments – 40km old, not yet run in
RB25DET head with VCT
Mild port and polish by JHH Engineering
Tomei poncams
Spool adjustable cam gear – inlet only
Power Enterprise head gasket
Oil drain from back of head to sump
Jun “style” inlet plenum – looks like factory runners or a copy on a FF plenum
BMI 80mm throttle body
Splitfire coil packs
Deatschwerks 740cc injectors in factory rail
Sard FPR
Walbro 500hp intank, Bosch 044 external, 500ml surge tank externally mounted
Signature Performance merge collector high mount exhaust manifold – steampipe, HPC coated black
Garret GT3582R .86 exh housing – Compressor cover polished. Surge ported and “windowed” by MTQ
Tial 38mm external wastegate plumbed into exhaust
3.5” dump – 3” straight through “cat” – the remainder of the exhaust is 3” mild steel, 1 hotdog resonator and a 5 Zigen stainless oval muffler w/ 4 or 5” tip – the exhaust is relatively quiet considering the limited restriction and the amount of power the car makes
600x300x100 FMIC
Turbosmart type 2 BOV
Mahle pistons
Argo rods
ACL rings and bearings
Nissan N1 oil pump with aftermarket CNC gear
ASR baffled and gated sump – 6.5L
Remote oil filter and 13 row cooler
JJR Alloy GTR oil air separator/washer bottle - modified
Ross tuffbond harmonic balancer
50mm alloy radiator – new black Gates hoses
Garage Defend carbon fibre air guide
New Nismo engine mounts
Lightweight Jap flywheel – not sure what brand
Excedy twin plate clutch
Redline shockproof oil
Shimmed stock VLSD
ECU/Electronics:
Haltech e11v2
Turbosmart eBoost 2
Autometer oil pressure and temperature gauges
+ other things I have probably forgotten
[Comments:[/b]
Car was last tuned to 467 rwhp and some ridiculous amount of torque(I’ll find a dyno sheet). That engine expired, the only surviving parts being the head and rods. It has since been rebuilt by Daniel Kent at Elite Racing Developments and has been on the dyno for 30 mins to check the AFRs and set a rev limit for run in. The rev limit had to be set at 3200rpm as the car is making 14psi at 3500rpm. The new engine sounds a lot smoother than the original one (built for a track car - I bought it 2nd hand – it had a few laps on it so was always going to be a hand grenade I guess). The tuner says this engine feels stronger than the old one so I’d expect some decent numbers once it’s run in.
I’ve owned the car since Feb 2004 and built it from a car with an exhaust, MBC and SAFC to what it is now. It has been religiously maintained during its time with me (maybe that’s why I’m divorced now...) and even though I do track the car occasionally I don’t abuse it. Oil is changed every 5000km with Motul 8100 excess, brake fluid is Motul RBF600, Redline gearbox oil, diff oil changed about 50000km ago
I’ll put the usual “no time wasters” bit here, but I doubt anyone would be interested because their cousins friends uncle probably knows where they can get the same car heaps cheaper.
Seriously though, there will be no test drives, anyone seriously interested can ride as passenger, pay for a dyno run or hand over a serious deposit.
Price:[/]
$25,000 firm
Ipswich, QLD
Contact:
Pm, Post or txt 0414 249 292
Currently registered until Sept 09
A few minor things have changed since this pic, I'll get some more up soon
https://www.sau.com.au/forums/topic/281646-1993-series-1-r33-gtst-black/
  • 1 month later...
  • 5 weeks later...
  • 4 weeks later...
Sad to see you sell it Waz.
If anyone needs any more specific details I can be contacted on 38072789 or email at [email protected]
This thing is seriously an ANIMAL!
A few of the details up top are incorrect like Cam gear is on the exhaust side, and the engine is completely run in, has done just over 1000km and still retains my warranty up to the 5000km mark.
Thanks Dan :down:
I spotted a few errors after posting originally but the stupid "no edit after X mins" means it now can't be changed
A bit more info. Just drove from Brisbane to Sydney - 35 degree day, oil temp sat at 80 degrees the whole way, oil pressure sat on 90 psi @ 3000rpm the whole trip, fuel consumption was 8km per litre (12.5L per 100km) consistently with mixed driving and aircon on about 50% of the time.
The car will be in Sydney until Monday if anyone is interested.
Thanks Dan :)
Went for a ride in this car in sydney, seriously fast car!!!!
not for the faint hearted..... :)
sad to see Wazza let it go!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
