Parting 180sx
ENGINE
SR20DET Engine and gearbox $2500
Fresh imported engine from just jap with receipt
BODYWORK
180sx body kit black $200
Rear bar, side skirts, half a front bar
Gandor tail lights $200
SHELL
Stripped shell with many bits $1500
Bits include
Full interior
Loom
Subframe
Steering rack
Doors, panels, glass etc
Repairable
INTERIOR STUFF
Nardi steering wheel $250
Boss kit with quick release kit $150
Nismo gear knob $70
Bee R Rev limiter $250
Apexi turbo timer $100
Apexi AVCR boost controller $600
Seven racetech gauges $200
With wiring and sensors
boost, oil temp, oil pressure, water temp, voltmeter, air fuel ratio, fuel pressure
Sony head deck with speakers $100
Drift button $15
ENGINE STUFF
Alloy radiator $80
Splitfire coilpacks and ignition system $350
Walbro fuel pump $80
Front mount intercooler kit with piping and blow off valve $250
3" Straight through exhaust turbo back $300
Mandrel bent, high flow cat and heat wrap
BRAKES
s13 rear brake calipers $100
s13 skyline front brake calipers made to fit s13 $150
Brake master cylinder $100
Clutch master cylinder $80
Nismo braided clutch line $100
Nismo clutch slave cylinder $180
Tail shaft $100
Shimmed LSD $150
Five stud conversion kit $500
ICHIBARN from USA bolt on with genuine new wheel bearings
MU secret pads HC+ Near new $400
Slotted rotors for s14 s15 of five stud s13 $250
Near new
Nismo braided brake lines $200
R32 GTR wheels $600
With tires
Jnc wheel nuts $50
Tein super street coilovers $800
Rear white line swar bar $80
Kmac stut tower bars $200
Front and rear
OTHER STUFF
2x sr20 red top standard turbos $100 each
Turbo GT2871 disco spud ball bearing turbo $700
with full braided lines!
2x sr20 red top heads with cams and bits $300 each
2x sr20 bottom ends $400
One seized from fuel in oil
One turns detonated piston 2
2x sr20 exhaust manifolds $80
2x sr20 intake manifolds $80
ECU red top standard $100
ECU red top nistune! $350
Can retune!
Tuned for 300HP fmic, disco spud and greddy easy cams
Will need retune depending on your application
S15 injectors $100
z32 airflow meter $100
PICKUP ONLY
In process of stripping car
NO time wasters
For pictures http://www.skylinesaustralia.com/forums/Re...sa-t281470.html
Chris -0423428670
hehe… Judging by your spelling you've had a few too many b*eers rod…
fark off you,i need a beer limiter :) arrrgggghh
anyweys,you gonna post smaller items matey?
very keen on the limiter
hey mate.
will take the:
tail lights
body kit ( does it come with both side skirts... both undamaged?)
walbro fuel pump. (how long it been in there for)
hi flow cat
teins ( condition. how many kms)
s15 injectors
z32 airflow meter. (comes with plug?)
cheers mate. will pick up on thursday afternoon.
0402522794
hey mate
as per messages ect
i'll def take the coilovers, sold my wheels today so will be able to pick up on wedsnday (payday :) ) when ever your free.
would like to talk to you about some other parts aswell, will message you in a couple hours.
cheers
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
