Hi all,
I would like to completely remove the HICAS system in my R34 GT-R (instead of just a cancel rod etc etc) because of the weight saving (20kg's?) and the benefits in handling but am curious to know the procedure for R34 GT-R's... I have read the threads which describe the R32/R33's but its not a complete removal... just cancel rods and not on an R34 GT-R...
Im guessing that it would be pretty much the same, (Ie - remove the rear steering arm, fluid resuviour tank/lines & motor in the boot) but I am interested to know of other R34 GT-R owners who have done this before...
Cheers,
Edited by xanavinismo
https://www.sau.com.au/forums/topic/281675-complete-r34-gt-r-hicas-removal/
umm its not the same as a 32 at all as it's not a hydraulic system. there are no lines to the front of the car or solenoid in the engine bay to worry about. the resoviour in the boot is for attessa not hicas.
as for the actual hicas rack - the lock washer option locks the standard rack in place, or you can get a hicas lock bar to replace the standard motor. If you really want to remove it altogether you would need to convert it to an s13 style setup with tie rods instead of a hicas rack....there is some information of how we did this in our racecar in the Builds section
Thanks for your info duncan. So the hicas motor does weigh a fare bit? Also, does that mean I wouldnt have the problem of having the HICAS light coming on because there is no solenoid in the engine bay?
Cheers,
Glen
I found these Midori Hicas Cancellers... it looks like it will save a heap load of weight!
Link: http://www.midoriseibi.co.jp/tuning/others...-canceller.html
Also appears that they bolt up to the standard mounts where the Hicas normally goes with no bar in between what so ever. Although more expensive than a 'Cancel Rod' these seem like the closest thing to complete removal of Hicas without much fuss!
However, has anyone ever used these?
yeah, but the brace doesnt get rid of the hicas unit itself so no real weight reduction.
just googling 'midori hicas canceller', there seems to be somewhat of a review on the product: http://minkara.carview.co.jp/userid/424045...0193/parts.aspx
not much info, but its got a pic and looks like what you're after.
  • 5 years later...
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
