hey guys, I recently "chose" to put my airbox back in and take my pod setup out and im wondering how people got there intake/snorkel to work with a fmic where the piping runs around the front of the motor? How have people got around with obsticle because i beleive the snorkel hits the pipe. any ideas?
or if theres any neat ideas to get some cooler air into the airbox?
cheers
https://www.sau.com.au/forums/topic/281684-airbox-snorkel-question/
Really without a picture so people can see what you have got space wise people can not be much help. If you can't fit the snorkel just chop a hole in the airbox and run some pipe from your front bar (assuming you have a vent on it somewhere) to the airbox.
Edited by GT-RZ
i know what you mean. the snorkel doesn't really fit back on with the crossover type fmic. putting a hole in the bottom of the airbox isn't a good idea as i'm pretty sure the snorkel goes into the top of the airbox so a hole in the bottom is going allow unfiltered air into the engine. not the best idea.
may i ask why you want to swap back? if it is just to stop hot air then i would just make a partition around the pod.
most people hack the snorkel on the side that the crossover pipe fouls on the snorkel and put on a new wall...
Bit of a hack job, but unless you change the pipe, two solid objects can't take up the same space...
yea i was thinking similar, or i was going to turn the airbox lid around so the opening was toward the guard then run something down, i dunno yet :-/
Thanks for that suggestion, ive been trying to figure out a way to get over 300rwkw whilst still using the factory air box, my cooler piping takes the standard route so the snorkel fits but if i can put a second one on the other side and draw cold air from behind the headlight i should be good since the box will apparently be good for 250rwkw in standard form.
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
