Ok kiddies - what game we wanna get into this week?
Date: 6th Aug
Time: 7pm AEST
Another CS:S night?
How many people can make it?
Server IP: 203.34.186.29:27075
Password: SAUSAU
Time: 7pm-8:30pm & 8:30pm - 10pm. AEST
There will be a 2-3 min delay between bookings while the server resets, so please just rejoin :devil:
DISCUSS
https://www.sau.com.au/forums/topic/281704-sau-online-gaming-night-4/
  • Replies 44
I MIGHT be able to make it... I haven't really had time to fix my computer, I've just got a fresh windows install on it and that's it...
CSS is easy, it seems as though most people have that... stick to what we know... I say throw a surf map on there for fun this time, I'll teach ya how to play :devil:
Im in and im down for any of the following.
CS
CS:S
COD 4
COD WAW (though i dont like it)
Crysis
Crysis Warhead
L4D
Fear 2 (if it has multiplayer i dunno, pretty sure it does)
GRiD (if anyone is feeling adventurous)
Most of them are not installed so whatever we decide give me a day or two's notice to reinstall and patch etc.
Well i'm down...I just got a new HDD for my PC and installed Vista....Just need to install my Orange Box Disc again so I can get my games going.
CS:S will be good (since most of you guys have been playing)
TF2 would be good - just need a decent amount of people playing
L4D is good but it's stuck to 4 on 4 max mulitplayer
COD5 would be good to (I currently have that installed on my PC already)
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
