Hey All
Ok So i got R33 S2 mods are
cat back zorst
R34 stock turbs
Vi-pec ECU
EBC
Pod
Catch can
Plumback BOV
Im currently having overfueling issues where its blowing alot of smoke and getting the old black match on the back of the car near zorst..... I was wondering if anyone could help diagnose the problem. Can was tuned to run 8psi on low and 11 on high and only makes 187rwkw's...
I also about a month ago changed from a Atmo BOV to a Plumback BOV... The tune was with the Atmo one on so could this be a contributing factor or ? also i think a mate cranked the boost up a few psi when he borrowed it as its seems to smetimes get up to about 13psi on gauge but that may just be a dodgey gauge reading.
Any help will be greatly appricated.. cheers
https://www.sau.com.au/forums/topic/281716-fuel-map/
my suggestions
get it tuned on the safest possible boost you can run, so 11-12psi, why bother with "hi" and "low"
get the tuner to drive the car on the road with you driving, and get them to wideband tune it and lean out the cruise AFR's
basically it sounds like youve been given a max power tune which is where the plonk the car on the dyno
do the basic settings, set your boost, floor the ass out of it on the dyno and tune the max power curve and settings
now thats great if you constantly drive your car at full throttle non-stop, but im guessing, like most owners
you are typically on max throttle about %5 of the time, the other 95% is on light cruise
so its critical as part of the tune, they either tune the light cruise AFR's on the dyno, it has some sort of auto-extrapolating, or the tuner does manual guess/extrapolate
or they drive it on the road and tune with a wideband sensor
also double check 02 feedback is on, if this ecu supports it
without 02 feedback, it will waste some fuel and become black
but without 02 feedback or 02 sensors a proper on-road wideband tune will negate the need for it
https://www.sau.com.au/forums/topic/281716-fuel-map/#findComment-4747257
    • To install new hicas ball joints do i really need to pay for the Frenchys hicas install tool? Or can i use something like this? https://www.ebay.co.uk/itm/395524214497?_trkparms=amclksrc%3DITM%26aid%3D1110018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26asc%3D281023%2C280568%2C280618%26meid%3D4018390c9ba246f794ed58b8b19ec80a%26pid%3D101430%26rk%3D4%26rkt%3D12%26sd%3D205160403603%26itm%3D395524214497%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DCompVIDesktopATF2V2AndXaiHotClickWithCompV6WithEbertNRTRecall%26brand%3DUnbranded&_trksid=p2332490.c101430.m2460&itmprp=cksum%3A3955242144974018390c9ba246f794ed58b8b19ec80a|enc%3AAQAKAAABMDJfxvEKz%2FWsdyy97PIVwAhtkTIJPGKp%2Bu7TYjjsvNO4eN9duTRR%2FSVFYts6UXmN8tSK75ee0LypjLaKkPNQ2gkat4DyNLnViXKBVpI1%2B5fAYfWiGJa5QlqEPseqbSJUD9gVo2KSXbnmQjuPDJH4flTH2bOLSO%2FvMrLjgPDIc7vGrlKtoSauZb0q%2Fu43zLR0J8tg1z5dPMV%2FcHtnqRYXb7R7V8G%2FrQGhpY1sWtGJXc4TWc78ccs69UXnMiCqqd05ITd%2BY7Vwbq5Uzd%2FWhmiZCytO66vqDnbJn03qN%2Bin0ImF5sgbgu9uD45tXNN8cr4IWfqzIEEpaKcgqilwbTDxMkIQ4sGcgz7IhYONV017vE6P9ksZ7n%2FFVwgs3kAfMb0%2FLGjwaqhwo0yilTIjGHg9mwU%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01JMR0X9WMB8DPEX82P2P3CRXN
    • I would be lying if I said I wasn't interested in what MCM were going to do with the NC I really enjoy their banter and occasional collaborations (like Alan from TSF, Ben from BCW, or any of the Haltech guys throwing around their experience), and I have probably watched everything they have put out
    • Not yet, we basically drove it to a private road, got the logs and drove it straight back. I think I need a new passenger seat belt after the mrs squeezed the life out of it.
    • Sounds insane! 🤤🤤🤤  Do you have any vids of it driving?  A flyby would be nice!
    • The prices of NCs are going to go up thanks to you... and partially the MCM guys.
